beyond55
Question about the influence of memory size on power consumption while reading or writing the memory
I want to do some modification on my design. It will separate a memory into two smaller memory. The total size of this two memories is just 56% of the original. But the total number of accessing memory will increase. I need to evaluate if the power consumption less than the original.
Can anyone give me some suggestion or guidance?  Thanks!
zhex
Are you talking about a Xilinx BRAM or an external memory?
If you are talking about a Xilinx BRAM, you could estimate the power comsuption in XPE.
http://www.xilinx.com/products/design_resources/power_central/index.htm
If you are talking about an external memory, you should probably contact the memory vendor. Below is a link of power calculation tool in Micron site
http://www.micron.com/support/part_info/powercalc
zhex
beyond55
Thanks for zeusgone.
But, is it a only way? Can use some method to analyze it instead of using this tool?
Thanks!
