davidhuo
Questions about BRAM INIT value
I create a ROM rom_4096X12 , initial it wih value like this in coe:
33  22  11  00
77  66  55  44
BB AA  99  88
FF EE DD CC
.......repeat......
when it is finished implement, I opened it by fpga_editor, the mem had been mapped to 4 BRAM32
the value of each BRAM32 are all repeat, here is the INIT_00 of 4 BRAM32
ram[0]: INIT_00:  ......cc884400 (repeat 256bit)
ram[1]: INIT_00: .. .....6E4C2A08
ram[2]: INIT_00:... ....FBEAD9C8
ram[3]:INIT_00: ... ...1F170E06
the ram[0] is correct , it is the low 8bit value of ROM
but the ram[1:3] is not follow that rule
I suspect ram[1] shift 1 bit right, ram[2] shift 2 bits right , I can't figure out  the value of rom[4]
My question is how to use data2mem when the rom value has been encode ?
gszakacs
Professor
Professor
First I think there is a typo in your post.  You say 4096x12, but I suspect you meant to say 4096x32?
I think you're right about shifting.  It looks like CoreGen has used the "parity" bit of each RAM to generate a 9-bit wide 4K deep memory from each BRAM, even though it could have had enough bits using only 8-bit wide memory.  So the "missing bit" between the BRAMs must be stored in the parity bit using a separate initialization string.
It's likely that you'll have problems using this memory with data2mem.  There may be a way to force Coregen to use only the 8 "data" bits by telling it which primitive to use.  If not you may need to code this a different way in order to use data2mem.
By the way the 4th memory seems to follow the pattern (Upper bits shifted right three) so it only provides the upper 5 bits of the 32-bit wide memory.
-- Gabor
balkris
Have your tried with read back these value. this may be usability issue. I think you need perform read. Have you tried in simulation
Thanks and Regards
Balkrishan
