bjzq
RX_ Sync cannot pulled high level
I use vivado 2018.3 to load jesd204b IP core. After setting and instantiating, I open the IP automatically generated example project. After running the simulation, RX_ Sync is not pulled to high level. What's the problem.? I'm not connected to FPGA hardware, just running in vivado environment.
rkhatri
Hi @bjzq ,
May be AR#66354 can be useful.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
