framac
Reset signal in Clocking Wizard
I want to generate a MMCM in a block design with the signal reset but when I select the reset in the Clocking Wizard it is not added in the interface (please see file attached).
I use Vivado 2020.2.
Nikhil_Thapa
Hi @framac ,
Looks like you have enabled 'Dynamic Reconfig' option. If so, then selecting or deselecting reset option does not do anything. To add 'reset' pin in clocking wizard, you need to disable 'Dynamic Reconfig' option.
nikhil@logictronix.com
:::::Do not forget to Accept as solution, give Kudo and Share a post that you think is helpful:::::
framac
Yes I have enabled Dynamic Reconfig. I understand the reset PLL signal can't be enabled in this case so it shouldn't be accessible in Clocking Wizard.
