vhdlveri123
Simplex Aurora reset sequence
Is the resetting sequence necessary for aurora initialization? I am using two IP one as TX and the other one as RX, and the TX is configured as master, so this is driving the RX clock and reset. So is it necessary to have a reset sequence?
kdeshwal
Hi @vhdlveri123 ,
Yes, reset sequence is necessary.
Check out the Use cases 3 from UG074, page-71
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
vhdlveri123
okay, so is this the same case for duplex?
When i checked with duplex, it was working without any reset sequence.
