mildred
Timing optimisation inside FIFO Ip
I'm trying to correct all my timing errors and i see one that is inside a fifo that i have generated with the IP catalog tool of VIVADO.
I am using a KU115
Here are some screenshot of the problematic timing path
And i'm wondering how i should correct this error as it seems to be inside the FIFO IP
Thanks for your help
pthakare
Hi @mildred
Can you please share the FIFO generator configuration here?
Did you checked example design timing for same configuration ?
You can create the example design by right click to IP-> Generate example design .
