basti2357
Ultrascale+ GTY Aurora64b66b 4-Lane 100G PCS loopback gt_pll_lock triggering
I'm testing Aurora64b66b as 4-Lane Configuration on Ultrascale+ GTY Transceivers at maximum line rate.
For simulation everything works well. When implementing the design on a ZU28DR gt_pll_lock, rx_fsm_resetdone, tx_fsm_resetdone, and link_reset toggle. This occurs for both PCS loopback using one core and normal operation with two cores connected using a QSFP-DAC.
-User clock is generated
-qplllock stays high
-rx_bufstatus is 3'd0 for each lane
The core is configured as Duplex, 4-Lane, INIT CLK is 100MHz and GT_Ref is 161.1331MHz both generated from an Ultra Low Jitter Clock Generator on the PCB.
Thanks in advance,
basti2357
rkhatri
Hi @basti2357 ,
This AR may be helpful here to debug the Reset issue.
https://www.xilinx.com/support/answers/59435.html
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
