Using the Block Memory Generator Native interface.
I am learning FPGA design using Verilog and I am having issues using the Block Memory Generator. I am using a Basys 3 dev board with an artix-7. I feel I am making a mistake in my code, but can't find it. The Generator is customized to be single port with 8 bit width of read and write, and 256 word depth. It is also set to write first. Thanks for you help.
module mem_top(
    input clk,
    input [4:0] BTN,
    output [15:0] LED
    reg mem_clk = 1'b0;
    reg [7:0] addr = 8'd60;
    reg [7:0] din = 8'd45;
    reg [7:0] ledoutput = 8'b0;
    wire [7:0] dout;
    reg en = 1'b1;
    reg wen = 1'b0;
    reg hasWritten = 1'b0;
    reg hasChanged = 1'b0;
    reg isPressed = 1'b0;
    reg testled = 1'b0;
    assign LED[7:0] = ledoutput[7:0];
    assign LED[14:8] = 8'b0;
    assign LED[15] = testled;
    blk_mem_gen_0 mem(
        .clka(mem_clk),
        .dina(din),
        .douta(dout),
        .addra(addr),
        .ena(en),
        .wea(wen)
    always@(*) begin
        if(hasChanged == 1'b0) begin
            ledoutput <= dout;
            hasChanged = 1'b1;
        end
    end
    always@(*) begin
        isPressed = BTN[0];
    end
    always@(*) begin
        if(isPressed) begin
            if(hasWritten == 1'b0) begin
                testled = 1'b1;
                wen = 1'b1;
                mem_clk = 1'b1;
                mem_clk = 1'b0;
                wen = 1'b0;
                hasWritten = 1'b1;
            end
        end
    end
endmodule
Re: Using the Block Memory Generator Native interface.
Hi @killbox998
What is the anomalous behavior with this code ? Are you not getting proper output on LEDs.
Please clarify further to gain the better insight.
The LEDs do not light up. The test LED does but none of the others.
Hi @killbox998
What is stored content of  address 8'd60 ?  Did you performed the behavioral Simulation?  Share your project to check at our end.
