Utility Buffer can't change the value of IBUF_DS_ODIV2 and BUFG_GT_O pins
I'm using the utility buffer to provide a clock to Vid_phy_controller while running a synthesis, it fails to set clock pin values. expected value to be set 1. But utility buffer show warning, the value is read-only and the default value is set 0.
Kindly let me know how fix it.
Platform: ZCU104
Vivado 2019.1 version is used.
Following is the error log:
[Common 17-53] User Exception: No open design. Please open an elaborated, synthesized or implemented design before executing this command.
[BD 41-737] Cannot set the parameter ASSOCIATED_CLKEN on /util_ds_buf_0/IBUF_DS_ODIV2. It is read-only.
[BD 41-737] Cannot set the parameter ASSOCIATED_ASYNC_RESET on /util_ds_buf_0/IBUF_DS_ODIV2. It is read-only.
[BD 41-737] Cannot set the parameter ASSOCIATED_CLKEN on /util_ds_buf_0/IBUF_OUT. It is read-only.
[BD 41-737] Cannot set the parameter ASSOCIATED_ASYNC_RESET on /util_ds_buf_0/IBUF_OUT. It is read-only.
[BD 41-737] Cannot set the parameter ASSOCIATED_CLKEN on /util_ds_buf_2/IBUF_DS_ODIV2. It is read-only.
[Common 17-107] Cannot change read-only property 'DEFAULT_DRIVER'.
Resolution: Please refer to Vivado Properties Reference Guide (UG912) for more information on setting properties.
Hi @madan_1993
I do not understand why you cascade the 2 utility buffers. This is your issue because the is no path inside the FPGA for this. You need a single utility buffer
Florent
