xujialin1992
V-5 and K-7 aurora, lane_up=1 but channel_up=0.
hi there.
I have two boards V5-SX956 and K7-325t.
V5 is tx simplex and K7 is rx simplex. Aurora 1.5Gbps, 1X
I monitor the signals in K-7, lane_up is high but  channel_up is low.
Is V5's aurora sequence is differtent with K-7's aurora sequence?
what's that mean when I keep receiving "bc4a 4a4a"?
rkhatri
Hi @xujialin1992 ,
Which version of IP you are using here?
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
