07-06-2013 01:47 AM
I used the IP Catalog to generate an independent clock FIFO from BRAM where the write size is 64 bits with a depth of 512 and the read size is 8 bits with a depth of 4096. I am not seeing my expected results.
The simulation shows several things:
Have I misconfigured the FIFO somehow, or is it misbehaving?
Daniel
07-30-2013 10:33 AM
This seems bug with FIFO Generator IP and will fixed in 2013.3 release
Balkrishan
07-22-2013 11:02 AM - edited 07-22-2013 11:11 AM
Can you please confirm if you have wrote your own FIFO code or you are using FIFO Generator code.
I am assuming you are using FIFO Generator core with independent clock and BRAM as memory resource.
Can you please send me the complete xco file.
You need to make sure you are driving all the inputs correctly.
We have provided test bench with FIFO Generator core.
You can use provided test bench and see if you can reproduce the issue
07-22-2013 07:03 PM
I am using the FIFO generator. The full source snapshot is attached to my posting. I will also try the Test Bench.
Daniel
07-22-2013 11:40 PM - edited 07-24-2013 10:12 PM
It seems you have not derived input signals correctly. Please refer pg057 for detail example section and use provided test bench with the core.
You can also refer interface debug section and quick start example design.
There are few timing figure are given in datasheet you can see how the input signal are asserted and how the output signals responding with input signal
For example
Write operation
Check fig 3.2 in PG057
Read operation
Check fig 3.3 in PG057
Hope it will help you
07-27-2013 06:53 AM
OK, so I took a look at the test bench, which is all in VHDL, even though I built my project in Verilog.
The test bench does not even look at the counters, so it cannot be said to judge them as working or not working.
The test bench continues to write into the FIFO after it is full, so it cannot tell if the FIFO only works when it is overfilled or if it will work when it is partially filled.
The test bench fills up the FIFO with the same value over and over again, so it cannot tell if items are pulled out of the correct memory location in the correct order or not.
When I run the test bench it tells me it failed:
INFO: [Vivado 12-1390] *** Running xsim
with args "fifo_generator_64_8_tb_behav -key {Behavioral:sim_1:Functional:fifo_generator_64_8_tb} -tclbatch {fifo_generator_64_8_tb.tcl} -log {fifo_generator_64_8_tb_behav.log}"
Vivado Simulator 2013.2
Time resolution is 1 ps
WARNING: Behavioral models for independent clock FIFO configurations do not model synchronization delays. The behavioral models are functionally correct, and will represent the behavior of the configured FIFO. See the FIFO Generator User Guide for more information.
Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).
STATUS:
00
INFO: [Vivado 12-1395] XSim completed. Design snapshot 'fifo_generator_64_8_tb_behav' loaded.
launch_xsim: Time (s): cpu = 00:00:08 ; elapsed = 00:00:08 . Memory (MB): peak = 3956.531 ; gain = 14.117
run 200 us
STATUS:
80
Error: Data mismatch found
Failure: Simulation failed
I have attached a snapshot of the test bench.
Daniel
07-30-2013 06:50 AM
Can you please try on Modelsim Simulator. We have seen such behavior with NCSIM
07-30-2013 10:33 AM
Balkrishan
08-01-2013 06:33 AM
Many thanks, Balkrishan.
I will pick it up and test it when it is available.
Daniel
08-01-2013 10:31 PM
Hello Daniel,
Thanks for your reply. As you would be trying the same in 2013.3, I would be marking the post from Bala as an Accepted Solution for others to refer in future.
Moving forward, if you have any post and you think that the reply from any user is helpful, you can mark it as an Accepted Solution.
We truely value your contribution towards making our tools more robust by highlighting various issues you face and please feel free to create new posts with new queries.
Best of luck!
08-02-2013 06:05 AM
Thanks for your feedback, but saying that someday I might get a solution is not what I would yet call an acceptable solution. To be a solution it has to solve my problems. What I have so far is a promise--which is good--but not yet a solution.
Daniel
