gnale
Vivado Cordic ipcore compute question
CORDIC_IPcore choose the Vector Rotation mode, since from the pg105
I get the Rotate mode computition give the result like that:
X'=cos(R)*X-sin(R)*Y
Y'=cos(R)*Y+sin(R)*X
and X,Y should be 2QN, R should be 3QN, when I set input Data as 32bit X + 32bit Y
as example
Y 2Q30 0x76980=0.007261634
X 2Q30 0x315480=0.003010869
R 3Q29 0xeccc680=0.462497
to output result with
X'  0x959cf7=0.009131662
Y' 0xfff597e6=-0.000635171
but by the computition formula
the result should be X' -0.000545475, Y' 0.007842137
what the mistake should be ? Is the DataSet wrong or the setting is wrong?
gnale
The compensation Scale Compensation should be Embedded Multiply then It can be used as this mode .
