bhanu27
What template to use to instantiate BRAM Controller in RTL
How can i instantiate AXI BRAM controller in RTL.
I know how to do it in block diagram. I was wondering what template
to use to instantiate AXI BRAM controller in RTL.
pthakare
Hi @bhanu27
There is no readily available template for AXI BRAM controller . The only option is to use the AXI BRAM controller IP through IP catalog or in block design ie IPI flow.
I.e in RTL you can use the AXI BRAM controller IP as well.
Reply if you have any queries, give kudos and accept as solution
