'X' value in built in fifo simulation
Hi every body
i want to simulation a built in fifo in vivado (this is very simple) but i get 'x' value  in full and empty output of fifo.
i use common clk built in fifo and this situation is appeared, but when i use common clk block ram every thing is ok.
what is the problem?
my files is attached.
i know that although in ug473, chapter 2 is said that WREN input should be held low for two clk period after RST deassertion but when i held it for 5 clk every thing ok. why is that so?
Hi @hrmt
Checked the Behavioral and Post Synthesis and Implementation Simulation at my end.
Behavioral Simulation:
1. Wr_en Assertion , 2 clock cycle after reset deassertion (Unexpected behavioral)
2. Wr_en Assertion , 5 (or more) clock cycle after reset deassertion (Expected Behavior)
I will check this internally . Did you get a chance to perform the post Synthesis /Implementation Timing Simulation?
I have tried to run the post Synthesis Simulation bit getting error related to reset cycle.
Reply if you have any Queries, Give Kudos and Accepts as solution if you get one
Hi @pthakare
thanks for quick answer
unfortunately when i see this behavior (this is unreliable), i use common clk block ram instead of built in fifo.
I will be very glad, if you know reason of it and tell to me.
