sa_fpga
XPM CDC Generator v1.0
Dear Xilinx Support,
I run into some problems with adding a "XPM CDC" IP to a block design.
If I double click it in "IP Catalog" i get an error "IP xpm_cdc" can be used within IP intregrator only.
If I try to add it in existing block design I get an error "The selected IP "xdc_cdc" is not supported in IP Integrator and therefore cannot be added to block design.
Both error message are somehow conflicting
Used Vivado Version: Vivado v2020.1 (64-bit)
Best Regards
pthakare
Hi @sa_fpga
xpm_cdc IP support is from VIVADO 2020.2 ,
I just checked in VIVADO 2020.2 and able to add.
I will check the support of this in 2020.1 and why its appearing in IP catalog.
pthakare
Hi @sa_fpga
sa_fpga
Hello pthakare,
thank you for the possible explanation.
Best Regards
