aurora xilinx ip instantiation problem with xilinx ise tool
hello sir,
 I generated the core with Aurora 8B10B 5.2, 1 lanes, lane width 2, Line rate 3.125 Gbps, GT refclk 156.25 Hhz, Duplex, Framing and no flow control, in Xilinx ISE 13.2 version. after generation of HDL code of Aurora ip and instantiat wrapper in top design module. but when i run sysnthesis it gives error
ERROR: Core Generator generated file aurora_1/src/aurora_1.vhd was not found.
ERROR: Unable to find top-level HDL source file for core: aurora_1.
thanks
nmanitri
Hello arvind@dandotiya,
Can you please let me know the following details:
1. Which device you are targetting?
2. Did you try with ISE 14.7? If no, Please try in ISE 14.7 and share the results with us.
Naveen
csattar
hi arvind@dandotiya ,
can you please let me know the steps you have followed to create the design .
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
csattar
can you please let us know the update and as well as the is this issue is sloved ?
Chandra sekhar
