axi protocol checker PG101 text error
In PG101 April 4, 2018. See the following screenshot.
A "RREADY is Low" stays in a "converted" :)
Hi @arley1224
Thank you for repporting this editorial issue. I have added it in our system to have it fixed if the doc is re-opened for a new version.
Florent
Hi @arley1224
Florent
you are welcome!
