k.e.elsayed
change in coe file
I have a question about xilinx ise memory IP cores.
I use a .coe file to initialize the contents of the memory by selecting it during the IP core generator wizard, When i change the contents of the .coe file I have to re-generate the core for the changes to take effect which is a time consuming process, is there another way ?
Tags (3)
vsrunga
In simulation you can hand edit the .mif file which is a binary file generated by .coe file and will be available in IP_core directory, in hardware you can go for data2mem conecept details of which are explained in the  below pdf.
http://www.xilinx.com/Attachment/Xilinx_Answer_46945_Data2Mem_Usage_and_Debugging_Guide.pdf
Hope this helps.
Vanitha.
vsrunga
Hope this helps.
Vanitha.
k.e.elsayed
That worked
Thank you
balkris
The manual modification expected to work however not recommended to use. The reason is when you regenerate the core it will again update the mif file. I think better way to change the coe file and regenerate the core again. Hope it will help
Thanks and Regards
Balkrishan
emmettbradford
I generated a true dual port 16-1024 RAM.
I initialized with a COE.
A MIF was generated correctly.
Now changes to the COE do not update the MIF.
When I try to re-generate the core, it says all output products are up to date.
How do I effect the COE changes to the MIF and the core?
I am using Vivado 2016.2, on Win 10 64bit.
blk_mem_gen_v8_3_3
Emmett
balkris
you can reset the output product and regenerate the core . right click on core name --> reset output products
Thanks and Regards
Balkrishan
emmettbradford
That worked.
