02-19-2021 05:46 AM
we use vivado 2019.1 and modelsim SE-64 2019.2 to simulate fifo ip,
but data from fifo is 'xxx'
fifo ip is fifo_generator_v13_2_4;
why? how to fix?
thank you!
02-19-2021 05:51 AM
Is the reset to your FIFO active low? Are you showing it on your screenshot? Is the FIFO reset before writing to it?
02-19-2021 06:08 AM - edited 02-19-2021 06:10 AM
@mu ,
As mentioned above please show the FIFO signals explicitly in another screenshot post.
Remember that you should read the FIFO only when it has valid data. Monitor the fifo_empty signal and the write_data_count. You should go on reading as long as write_data_count > 1 and the fifo_empty is low. Else stop reading and wait till sufficient data is available again for reading.
why? how to fix?
I guess the problem is related to how you are controlling the write and read data to and from the FIFO. Please recheck the logic. Without looking in to your control logic RTL, I can't say more.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
02-19-2021 06:22 AM
please check the screenshot
02-19-2021 06:23 AM
the fifo is reset before writing.
02-19-2021 06:28 AM
One more time. Which signal is the reset to the FIFO? Is the reset active high or active low?
02-19-2021 06:49 AM
why is the valid going "unknown"
02-19-2021 06:49 AM
thank you very much for your reply!
we have fixed it
there are errors in RTL
02-19-2021 06:50 AM
thank you!
