sarlaga3
i'm now generating a zynq ultrascale+ mpsoc ip,,can i use the default setting for the ddr option
i'm now generating a zynq ultrascale+ mpsoc ip.iand  have choose the board zcu102 for the project when building the project.now i come to step to configure the ddr option in the zynq ultrascale+ mpsoc,can i use the default setting for the ddr option or do i have to change the default setting for the ddr option?why there is 4GB ddr capability on the zcu102 board and there is only 2GB ddr capability in the default setting for the ddr option?
anatoli
Hello @sarlaga3 ,
Please try to avoid double posting the same query. We can see you've posted the same in many other locations:
https://forums.xilinx.com/t5/Xilinx-IP-Catalog/i-m-now-generating-a-zynq-ultrascale-mpsoc-ip-can-i-use-the/m-p/1209048
https://forums.xilinx.com/t5/Xilinx-IP-Catalog/i-m-now-generating-a-zynq-ultrascale-mpsoc-ip-can-i-use-the/m-p/1209052/highlight/true#M9464
https://forums.xilinx.com/t5/Memory-Interfaces-and-NoC/i-m-now-generating-a-zynq-ultrascale-mpsoc-ip-can-i-use-the/m-p/1209055
For your other queries, you are seems done the same, which is not a recommended approach when posting your query on Xilinx Forums.
Please choose the correct board in the future, and post your query there once. Please be aware that moderators do checking their Forum boards, so if they see your post is not in the correct place/board, they will move this accordingly.
As such, please close this duplicate post and continues with the one on the Memory Forum board:
Thanks in advance and have a nice day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
