Observer markge
iic with secondary address
Need to communicate with IIC slave that have primary and secondary adress (register address) using microblaze SW. Don't see such capability for XIic_Send XIic_Recv functions. Looks like it has only primery adress and data. Have to send primery address, secondary adress, data as shown in the picture below:
Observer markge
Re: iic with secondary address
The solution is following:
1. For write cycle use array of two bytes, first byte is the register address, second is the data.
2. For the read cycle, write register address as write command (one byte) and read the data (one byte or more).
Observer markge
