527114591@qq.com
jesd204b ip关于cannot set LOC property
你好,我遇到关于这样的问题,不知道该如何解决,message提示约束被占用了? 谢谢
我用的器件是xkcu040,用了两个jesd'204b ip 分别取名ADCS and ADCM
[Vivado 12-2285] Cannot set LOC property of instance 'ADC_DATA_RX_INST/JESD204B_Data_Rx_Inst/i_jesd204_ADCS/inst/i_jesd204_phy/inst/jesd204_phy_block_i/jesd204_0_phy_gt_i/inst/gen_gtwizard_gthe3_top.jesd204_0_phy_gt_gtwizard_gthe3_inst/gen_gtwizard_gthe3.gen_channel_container[0].gen_enabled_channel.gthe3_channel_wrapper_inst/channel_inst/gthe3_channel_gen.gen_gthe3_channel_inst[0].GTHE3_CHANNEL_PRIM_INST'... Instance ADC_DATA_RX_INST/JESD204B_Data_Rx_Inst/i_jesd204_ADCS/inst/i_jesd204_phy/inst/jesd204_phy_block_i/jesd204_0_phy_gt_i/inst/gen_gtwizard_gthe3_top.jesd204_0_phy_gt_gtwizard_gthe3_inst/gen_gtwizard_gthe3.gen_channel_container[0].gen_enabled_channel.gthe3_channel_wrapper_inst/channel_inst/gthe3_channel_gen.gen_gthe3_channel_inst[0].GTHE3_CHANNEL_PRIM_INST can not be placed in GTHE3_CHANNEL of site GTHE3_CHANNEL_X0Y0 because the bel is occupied by ADC_DATA_RX_INST/JESD204B_Data_Rx_Inst/i_jesd204_ADCM/inst/i_jesd204_phy/inst/jesd204_phy_block_i/jesd204_0_phy_gt_i/inst/gen_gtwizard_gthe3_top.jesd204_0_phy_gt_gtwizard_gthe3_inst/gen_gtwizard_gthe3.gen_channel_container[0].gen_enabled_channel.gthe3_channel_wrapper_inst/channel_inst/gthe3_channel_gen.gen_gthe3_channel_inst[0].GTHE3_CHANNEL_PRIM_INST(port:). This could be caused by bel constraint conflict ["e:/MDO/verison/MDO_SampleSys_syncbefore_ilatb/MDO_SampleSys_syncbefore_ilatb.srcs/sources_1/ip/jesd204_0/ip_0/ip_0/synth/jesd204_0_phy_gt.xdc":57]
Fresh
