wrwadley
multiplier rdy signal?
Hello!
I am using the LogicCore Multiplier v11.0, and I am wondering what is the best way to know when the operation is completed.
There is no "rdy" signal that I can use. I suppose that I should either check that the product output is not zero, or wait a predefined number of clock cycles (based on the pipelining?).
What is the best way to handle this?
Thank you very much.
Bill
Tags (3)
gszakacs
Instructor
Instructor
Multiplier cores generally have a fixed pipeline delay.  This can vary depending on the
core parameters, but should either be shown in the last page of the CoreGen customization
or in the core datasheet.  If you have trouble finding the correct number of clocks to
match the core pipeline delay I would suggest simulating the core with a simple testbench
to see when the outputs change in simulation relative to the inputs.  If you have an
input valid signal you can delay it by the appropriate number of clock cycles to have
an output valid from the multiplier core.
HTH,
Gabor
-- Gabor
wrwadley
Thank you!
In my current testbench (where I discovered the delay), I see that it takes 5 clocks to get to the result. I also happen to have the multiplier configured with 5 pipelining stages. That, I believe, explains the 5 clocks. However, it is very nice to hear it from someone else that knows what they are doing.
Kudos to you!
Bill
