Smart_Tu
program and flash of the GTP core
Hello everyone! After I use the GTP core generating program in the IP core of vivado, the online program program can run normally, but after flash , there is a great chance that GTP will not work normally (that is, the program can not run, but sometimes it can run normally). Do you know the possible reasons and solutions? Please speak freely, I will try every one!
thank you!
rkhatri
Hi @Smart_Tu ,
Please try to toggle GTRXRESET and check if link comes up .
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
