传承双龙
vivado 2020.1 package new ip do not generate driver file
When I package an IP core with a AXI interface, version 2020.1 of Vivado does not generate C language driver files.
Snipaste_2020-08-25_16-52-08.pngCreate an IP core with a axi interface, then go all the way to the next step, and at the last interface you'll see that there's no hint of generating a driver file. As shown in the figure above.
But if you're using the 2019.2 version of Vivado, when you package an IP core with a AXI interface, it should look something like this:
You will be prompted to generate the Driver and TestApp....
So I wonder if I can get these C driver files in the 2020.1 version of Vivado
gsutter
Same concern... A bug or a new feature?
