saragrassi
where can I download the Zip files for the FIR and FFT bit accurate C models
Hello, I am following the application note "Polyphase Filter Bank Channelizer"  (in https://www.xilinx.com/support/documentation/application_notes/xapp1161.pdf) and I have download the code xapp1161.zip (https://www.xilinx.com/member/forms/download/design-license.html?cid=320021&filename=xapp1161.zip).
Now I would like to run the matlab function channelizer.m. In the guide (p. 6 of xapp1161.pdf) it says I should unzip and place the Zip files for the FIR and FFT bit accurate C models in: matlab/fir_cmodel and matlab/fft_cmodel. And the run the script, compile_bitacc_models.m, to compile the MEX executables.
It says that the Zip files for each supported platform can be downloaded from:
http://www.xilinx.com/products/intellectual-property/FIR_Compiler.htm
http://www.xilinx.com/products/intellectual-property/FFT.htm
However, I cannot find anywhere these Zip files  for the FIR and FFT bit accurate C models. Could you please help me in finding / downloading these files ?
Thanks and best regards,
Sara
sreejisg
I am also facing this issue, please mail the model to my mail ID , if you had received them sreejeesh@nielit.gov.in @saragrassi
@saragrassi @sreejisg
When you generate the FIR and FFT cores in Vivado, you will find a directory that contains the bit accurate C models.
Cheers,
Mark
sreejisg
can please share the vivado files for the channelizer (archive files)
sreejisg
can you please share the zip files for FIR & FFT to my mail ID sreejisg@gmail.com or sreejeesh@nielit.gov.in
@sreejisg
The FIR and FFT cores (and associated C models) are available in WebPack Vivado - a free download.
Mark
sreejisg
You can call the IP in vivado and get the C model from the simulation Window
