alexis_jp
xpm_fifo_axil independent clock "distributed": CDC constraint missing
I use xpm_fifo_axif with this instance:
xpm_fifo_axil #(
  .AXI_ADDR_WIDTH         (5),
  .AXI_DATA_WIDTH         (32),
  .CDC_SYNC_STAGES        (3),
  .CLOCKING_MODE          ("independent_clock"),
  .FIFO_DEPTH_RACH        (16),
  .FIFO_DEPTH_RDCH        (16),
  .FIFO_DEPTH_WACH        (16),
  .FIFO_DEPTH_WDCH        (16),
  .FIFO_DEPTH_WRCH        (16),
  .FIFO_MEMORY_TYPE_RACH  ("distributed"),
  .FIFO_MEMORY_TYPE_RDCH  ("distributed"),
  .FIFO_MEMORY_TYPE_WACH  ("distributed"),
  .FIFO_MEMORY_TYPE_WDCH  ("distributed"),
  .FIFO_MEMORY_TYPE_WRCH  ("distributed")
I get lots of huge inter-clocks timing from s_aresetn to m_aclk.
s_aresetn is synchronous to s_aclk.
Is that a known bug?
Same problem with xpm_fifo_axif only when the memory type is distributed.
alexis_jp
alexis_jp
And still not solved in 2020.2.
