psk1801
Bitbake command is failed
HI all ,
While running a bitbake command for petalinux , please find the command below
bitbake -c compile device-tree-generation
Please find the error below
Initialising tasks: 100% |####################################################################################################################################################| Time: 0:00:02
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: external-hdf-1.0-r0 do_deploy: Function failed: do_deploy (log file is located at /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/log.do_deploy.7292)
ERROR: Logfile of failure stored in: /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/log.do_deploy.7292
Log data follows:
| DEBUG: Executing python function sstate_task_prefunc
| DEBUG: Python function sstate_task_prefunc finished
| DEBUG: Executing shell function do_deploy
| sudo: no tty present and no askpass program specified
| WARNING: /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/run.do_deploy.7292:1 exit 1 from 'install -d /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/deploy-external-hdf'
| ERROR: Function failed: do_deploy (log file is located at /home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/build/tmp/work/zcu102_zynqmp-xilinx-linux/external-hdf/1.0-r0/temp/log.do_deploy.7292)
ERROR: Task (/home/pre-si-user/Desktop/Pushpendra/Xilix_Zync/sources/core/../meta-xilinx-tools/recipes-bsp/hdf/external-hdf.bb:do_deploy) failed with exit code '1'
NOTE: Tasks Summary: Attempted 387 tasks of which 386 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Please helo me
