Import xfDNN error
I am using ML suite 1.2 and I got a error message when I want to import xfDNN in python: The key error message is :
ImportError: /ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/caffe/../../../libcaffe.so.1.0.0: undefined symbol: _ZN6google4base21CheckOpMessageBuilder9NewStringB5cxx11Ev
Please help me to solve this problem.
The whole error message are:
>>> from xfdnn.tools.compile.bin.xfdnn_compiler_caffe import CaffeFrontend as xfdnnCompiler
['/home/jerry/projects/ML-suite/ml-suite-1.2/parallel', '/home/jerry/projects/ML-suite/ml-suite-1.2/bin', '/home/jerry/projects/ML-suite/ml-suite-1.2/version', '/home/jerry/projects/ML-suite/ml-suite-1.2/weights', '/home/jerry/projects/ML-suite/ml-suite-1.2/optimizations', '/home/jerry/projects/ML-suite/ml-suite-1.2/network', '/home/jerry/projects/ML-suite/ml-suite-1.2/memory', '/home/jerry/projects/ML-suite/ml-suite-1.2/graph', '/home/jerry/projects/ML-suite/ml-suite-1.2/codegeneration', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../weights', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../tests', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../docs', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../codegeneration', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../network', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../version', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../bin', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../pickle', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../frontends', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../graph', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../optimizations', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../fpga_definition', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../parallel', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../memory', '', '/home/jerry/projects/ML-suite/ml-suite-1.2', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/rt', '/home/jerry/projects/ML-suite/ml-suite-1.2/ext', '/home/jerry/projects/ML-suite/ml-suite-1.2/apps/yolo', '/home/jerry/projects/ML-suite/ml-suite-1.2/apps/yolo/nms', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/emu', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/network', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/graph', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/optimizations', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/codegeneration', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/memory', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/version', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/weights', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/parallel', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfmlp/python', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python27.zip', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/plat-linux2', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/lib-tk', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/lib-old', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/lib-dynload', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/pydot_ng-1.0.1.dev0-py2.7.egg']
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "./xfdnn/tools/compile/bin/xfdnn_compiler_caffe.py", line 53, in <module>
File "/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/caffe/__init__.py", line 1, in <module>
from .pycaffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, RMSPropSolver, AdaDeltaSolver, AdamSolver, NCCL, Timer
File "/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/caffe/pycaffe.py", line 13, in <module>
from ._caffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, \
Re: Import xfDNN error
The issue may be due to Environment not set
$ export XFDNN_ROOT=/ml-suite/xfdnn
$ export MLSUITE_ROOT=/ml-suite
I reinstall an anaconda virtual environment. This problem had been solved.
Having the same issue:
After activating conda; verifying the environment by importing caffe in pythonpython -c "import caffe"  generates the following error message:
ImportError: /home/.../anaconda2/envs/ml-suite/lib/python2.7/site-packages/caffe/../../../libcaffe.so.1.0.0: undefined symbol: _ZN7leve........SsPPS0_
Any idea?
hi,
I met the same issue, could you let me know did you resolved it? Thanks in advance.
In order to solve it, I had to reinstall some of the specific libraries in the error message in anaconda.
Apparently some updates of the packages causing the original install as described in the instructions to be incorrect
