tareksmaili
Library Issue with Xilinx ISe 9.2i
Hello everyone.
I am facing a problem with Xilinx ISE 9.2i and that problem lays in not recognizing an unsigned type, when I write an unsigned type it stays black and doesn't turn blue as when I type signed or any other type, to_unsigned works as well.
I used lots of libraries decleration but i just kept facing the same issue. Any help or clarification on the matter would be awesome, thank you very much for reading.
krishnagaihre
You might have placed your query at this "Design Tools-->Synthesis" thread:  https://forums.xilinx.com/t5/Synthesis/bd-p/SYNTHBD
Have you tried with using "use IEEE.STD_LOGIC_UNSIGNED.ALL;" on the library as following?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
krishna@logictronix.com
