ML605 Board: Ethernet problem
I am using ML605 in RGMII mode. I gave all the constraints and generated the bit file. I programmed it to the board but I am not able to see anything in the wire shark(not even the address). The addresses I gave are
source mac address : DEADBEEF0123
destination mac address : FFFFFFFFFFFF
source ip address : C0A40140
destination ip sddress : FFFFFFFF
I think this all F's is broadcast address.
krishnagaihre
@prasad_121601032  if you post your query at this thread then you might get answer much faster : https://forums.xilinx.com/t5/Other-FPGA-Architectures/bd-p/7Series. This thread is on Machine Learning while your project is ML605 implementaiton. It is just an personal sugessation!
krishna@logictronix.com
