rokmc612
ModuleNotFoundError: No module named
I have been ruuned the to compile for th setup.sh script which as /ml_suite/overlaybins/setup.sh
but, I got the error message as below
would you pls help me.
haroldlee@chanel:/home/dev/ml-suite$ source ./overlaybins/setup.sh
Using MLSUITE_ROOT
/home/dev/ml-suite
XILINX_XRT      : /opt/xilinx/xrt
PATH            : /opt/xilinx/xrt/bin:/opt/xilinx/xrt/bin:/home/haroldlee/bin:/opt/xilinx/xrt/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/cuda/bin
LD_LIBRARY_PATH : /opt/xilinx/xrt/lib:/opt/xilinx/xrt/lib:/opt/xilinx/xrt/lib::/home/dev/ml-suite/ext/boost/lib:/home/dev/ml-suite/ext/boost/libs:/home/dev/ml-suite/ext/zmq/libs:/home/dev/ml-suite/ext/hdf5/lib:/home/dev/ml-suite/ext/sdx_build/runtime/lib/x86_64:/home/dev/ml-suite/ext/boost/lib:/home/dev/ml-suite/ext/boost/libs:/home/dev/ml-suite/ext/zmq/libs:/home/dev/ml-suite/ext/hdf5/lib:/home/dev/ml-suite/ext/sdx_build/runtime/lib/x86_64
Using LD_LIBRARY_PATH
/opt/xilinx/xrt/lib:/opt/xilinx/xrt/lib:/opt/xilinx/xrt/lib::/home/dev/ml-suite/ext/boost/lib:/home/dev/ml-suite/ext/boost/libs:/home/dev/ml-suite/ext/zmq/libs:/home/dev/ml-suite/ext/hdf5/lib:/home/dev/ml-suite/ext/sdx_build/runtime/lib/x86_64:/home/dev/ml-suite/ext/boost/lib:/home/dev/ml-suite/ext/boost/libs:/home/dev/ml-suite/ext/zmq/libs:/home/dev/ml-suite/ext/hdf5/lib:/home/dev/ml-suite/ext/sdx_build/runtime/lib/x86_64:/home/dev/ml-suite/ext/boost/lib:/home/dev/ml-suite/ext/boost/libs:/home/dev/ml-suite/ext/zmq/libs:/home/dev/ml-suite/ext/hdf5/lib:/home/dev/ml-suite/ext/sdx_build/runtime/lib/x86_64
Using LIBXDNN_PATH
/home/dev/ml-suite/xfdnn/rt/libs/libxfdnn.so
PYTHONPATH
/home/dev/ml-suite:/home/dev/ml-suite/xfdnn/rt:/home/dev/ml-suite/ext:/home/dev/ml-suite/apps/yolo:/home/dev/ml-suite/apps/yolo/nms:/home/dev/ml-suite/xfdnn/tools/emu:/home/dev/ml-suite/xfdnn/tools/compile/network:/home/dev/ml-suite/xfdnn/tools/compile/graph:/home/dev/ml-suite/xfdnn/tools/compile/optimizations:/home/dev/ml-suite/xfdnn/tools/compile/codegeneration:/home/dev/ml-suite/xfdnn/tools/compile/memory:/home/dev/ml-suite/xfdnn/tools/compile/version:/home/dev/ml-suite/xfdnn/tools/compile/memory:/home/dev/ml-suite/xfdnn/tools/compile/weights:/home/dev/ml-suite/xfdnn/tools/compile/bin:/home/dev/ml-suite/xfdnn/tools/compile/parallel:/home/dev/ml-suite/xfdnn/tools/compile/pickle:/home/dev/ml-suite/xfmlp/python:/home/dev/ml-suite/xfdnn/rt/scripts/framework/caffe:/home/dev/ml-suite/xfdnn/rt/scripts/framework/darknet:/home/dev/ml-suite/xfdnn/rt/scripts/framework/base:/home/dev/ml-suite:/home/dev/ml-suite/xfdnn/rt:/home/dev/ml-suite/ext:/home/dev/ml-suite/apps/yolo:/home/dev/ml-suite/apps/yolo/nms:/home/dev/ml-suite/xfdnn/tools/emu:/home/dev/ml-suite/xfdnn/tools/compile/network:/home/dev/ml-suite/xfdnn/tools/compile/graph:/home/dev/ml-suite/xfdnn/tools/compile/optimizations:/home/dev/ml-suite/xfdnn/tools/compile/codegeneration:/home/dev/ml-suite/xfdnn/tools/compile/memory:/home/dev/ml-suite/xfdnn/tools/compile/version:/home/dev/ml-suite/xfdnn/tools/compile/memory:/home/dev/ml-suite/xfdnn/tools/compile/weights:/home/dev/ml-suite/xfdnn/tools/compile/bin:/home/dev/ml-suite/xfdnn/tools/compile/parallel:/home/dev/ml-suite/xfdnn/tools/compile/pickle:/home/dev/ml-suite/xfmlp/python:/home/dev/ml-suite/xfdnn/rt/scripts/framework/caffe:/home/dev/ml-suite/xfdnn/rt/scripts/framework/darknet:/home/dev/ml-suite/xfdnn/rt/scripts/framework/base:/home/dev/ml-suite:/home/dev/ml-suite/xfdnn/rt:/home/dev/ml-suite/ext:/home/dev/ml-suite/apps/yolo:/home/dev/ml-suite/apps/yolo/nms:/home/dev/ml-suite/xfdnn/tools/emu:/home/dev/ml-suite/xfdnn/tools/compile/network:/home/dev/ml-suite/xfdnn/tools/compile/graph:/home/dev/ml-suite/xfdnn/tools/compile/optimizations:/home/dev/ml-suite/xfdnn/tools/compile/codegeneration:/home/dev/ml-suite/xfdnn/tools/compile/memory:/home/dev/ml-suite/xfdnn/tools/compile/version:/home/dev/ml-suite/xfdnn/tools/compile/memory:/home/dev/ml-suite/xfdnn/tools/compile/weights:/home/dev/ml-suite/xfdnn/tools/compile/bin:/home/dev/ml-suite/xfdnn/tools/compile/parallel:/home/dev/ml-suite/xfdnn/tools/compile/pickle:/home/dev/ml-suite/xfmlp/python:/home/dev/ml-suite/xfdnn/rt/scripts/framework/caffe:/home/dev/ml-suite/xfdnn/rt/scripts/framework/darknet:/home/dev/ml-suite/xfdnn/rt/scripts/framework/base:
Traceback (most recent call last):
  File "<string>", line 1, in <module>
  File "/home/dev/ml-suite/xfdnn/rt/xdnn.py", line 13, in <module>
    import numpy as np
ModuleNotFoundError: No module named 'numpy'
Warning: failed to auto-detect platform. Please manually specify platform with -p
Using MLSUITE_PLATFORM
(unknown)
