kc.hsu
OSERROR: libboost_thread.so: cannot open shared object library
When I run : ". run/sh 1525 e2e" on my local fpga, it has the following error:
Traceback (most recent call last):
  File "/home/kc.hsu/anaconda2/envs/ml-suite/lib/python2.7/multiprocessing/process.py", line 267, in _bootstrap
    self.run()
  File "/home/kc.hsu/anaconda2/envs/ml-suite/lib/python2.7/multiprocessing/process.py", line 114, in run
    self._target(*self._args, **self._kwargs)
  File "/home/kc.hsu/ml-suite/apps/yolo/xyolo.py", line 144, in fpga_stage
    config['xclbin'], "kernelSxdnn_0", config['xlnxlib'])
  File "/home/kc.hsu/ml-suite/xfdnn/rt/xdnn.py", line 433, in createHandle
    createManager (libFile)
  File "/home/kc.hsu/ml-suite/xfdnn/rt/xdnn.py", line 429, in createManager
    _xdnnManager = XDNNManager(libFile)
  File "/home/kc.hsu/ml-suite/xfdnn/rt/xdnn.py", line 69, in __init__
    self._lib = cdll.LoadLibrary(libFile)
  File "/home/kc.hsu/anaconda2/envs/ml-suite/lib/python2.7/ctypes/__init__.py", line 445, in LoadLibrary
    return self._dlltype(name)
  File "/home/kc.hsu/anaconda2/envs/ml-suite/lib/python2.7/ctypes/__init__.py", line 367, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: libboost_thread.so: cannot open shared object file: No such file or directory
Before traceback, it shows:
INFO: Reading labels...
INFO: Running network input 608x608 and output 19x19
INFO: Entering XYOLO WITH
Finished batch 1
Process Process-1:
And when I trace the string of self._name , it shows:
'../../xfdnn/rt/xdnn_cpp/lib/libxfdnn.so')
It seems like I don't know where to check if I have libboost_thread.so and how to find it back.
For more info. about my setting:
I follow git branch v1.0-ea since I have a vcu1525 borad. Before getting here I change the version of the following things to:
caffe: 1.4.0
numpy: 1.14.5
upgrade scikit-image
