Display Image Classification GoogLeNet Demo
I'm trying to run Image Classification GoogLeNet v1Demo by using AWS
and I'm following https://github.com/Xilinx/ml-suite/blob/master/docs/tutorials/googlenet-demo.md
Step 5 states: From your host machine: the demo will display at the following web address: http://<yourpublicdns>.compute-1.amazonaws.com:8998/static/www/xdnn1.html
My Public DNS(IPv4) on AWS instance is empty, so I don't know how to display the demo in the browser.
Is the public dns a must to display the demo or I can do the same by using the private DNS? If private DNS can be used, what is the right address?
http://<myprivatedns>.compute-1.amazonaws.com:8998/static/www/xdnn1.htmldoesn't work.
Antonello
Re: Display Image Classification GoogLeNet Demo
Hi Antonello,
In your AWS console, make sure you instance is running and in the description tab you should be able to see the public DNS information. Sometimes you will need to refresh your console view for this information to populate.
Kamran
/k
Hi Kamran,
the instance is running, but after several refresh I can't see the public DNS information. I'm able to complete the demo up to step 4.
Antonello
I would recommend following this instruction:
https://github.com/Xilinx/ml-suite/blob/master/apps/perpetual_demo/README.md
Also, for your public DNS issue... this is a problem on your AWS side. Perhaps this will help? https://stackoverflow.com/questions/20941704/ec2-instance-has-no-public-dns
Google is your friend for that one.
Regarding the public DNS, the suggested solutions on Google don't work. It seems I'm not authorized to modify the options needed to enable the public DNS.
