Error when running ML Suite Docker Container
Hello all,
I'm try to run ml suite using ML Suite Docker Container. I downloaded the latest 1.5 version.
I followed all the step in the git repo.
But when running the following command to start interact with docker container:
sudo ./docker_run.sh xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-caffe-1.0-mls-1.5
I got the following error message.
omega@omega:~/mlsuit15/ml-suite$ sudo ./docker_run.sh xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-caffe-1.0-mls-1.5
Found xclmgmt driver(s) at
Found render driver(s) at /dev/dri/renderD129
/dev/dri/renderD128
Unable to find image 'xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-caffe-1.0-mls-1.5:latest' locally
docker: Error response from daemon: pull access denied for xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-caffe-1.0-mls-1.5, repository does not exist or may require 'docker login': denied: requested access to the resource is denied.
See 'docker run --help'
I also tried with tensorflow container, It also failed with same error.
However previously I was able to run docker for ml-suite 1.4v.
My current requiment is to run tensorflow models with ml suit. For that I need the tensorflow container.
Can anyone please help with this?
Re: Error when running ML Suite Docker Container
Hopefully this issue will be fixed soon. Meanwhile use this method:
sudo ./docker_run.sh <image-id>
The image ID is printed when you load the container using:
$ docker load < xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-tensorflow-1.12.0-mls-1.5.tar.gz
I think this will solve the issue for now.
Visitor luoz10rpi
Do "docker images". You might find that xilinx docker image becomes <none>:<nome> image.
Visitor luoz10rpi
Please try:
# TensorFlow
./docker_run.sh 5764b4f11309
# Caffe
./docker_run.sh 6909f7cd79d6
@omega_gamage
By running the following steps on command line will solve the issues for running "sudo ./docker_run.sh"
1>Download docker containers for ml-suite v1.5
For tensorflow
https://www.xilinx.com/member/forms/download/eula-xef.html?filename=xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-tensorflow-1.12.0-mls-1.5.tar.gz
For caffe
https://www.xilinx.com/member/forms/download/eula-xef.html?filename=xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-caffe-1.0-mls-1.5.tar.gz
 2>Now load the docker containers.
For tensorflow
sudo docker load < xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-tensorflow-1.12.0-mls-1.5.tar.gz
 For caffe
sudo docker load < xilinx-ml-suite-ubuntu-16.04-xrt-2018.2-caffe-1.0-mls-1.5.tar.gz
 3>Run docker images accordingly.
For tensorflow
cd ml-suite
sudo ./docker_run.sh 5764b4f11309d27b0aa0cf9fa56db5fe8d9035807773105bd83a21ff643d3a5f
5764b4f11309d27b0aa0cf9fa56db5fe8d9035807773105bd83a21ff643d3a5f -> this is image id obtained after loading tensorflow docker container.
For caffe
cd ml-suite
sudo ./docker_run.sh 6909f7cd79d6cdd62a718fd7555d91a8c995b12d4a925851514c6b4faf6d1a11
 6909f7cd79d6cdd62a718fd7555d91a8c995b12d4a925851514c6b4faf6d1a11 -> this is image id obtained after loading tensorflow docker container.
If you find this information useful, please add kudo for this reply and accept this as solution.
Thank you.
