Image capturing application problems under V4L2 with zcu102
Hi,all:
    I want to capture test pattern image use TPG in linux V4L2 . I want to save the image as file(yuv is okay)without display .  First , I run TRD (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842199/Zynq+UltraScale+MPSoC+Base+TRD+2017.4) on zcu102 . Everything is ok . Because I want to save TPG image without display , Then I killed the process .
I run "media-ctl -p" to view and initialize  the TPG pipeline.
Run "yavta -c10 -f YUYV -s 1920x1080 --skip 7 -F /dev/video4" to save TPG image , error occured.
Then I rerun the "video_qt"and started the stream by click "PLAY BUTTON", I got this
I stoped it ,Then rerun "yavta -c10 -f YUYV -s 1920x1080 --skip 7 -F /dev/video4" I got what I want
I don't know what has be done when I click "PLAY BUTTON" , In other word , what I need to do before starting to capture image.
I also created my vivado project refer to the TRD ,I build two TPG
Now ,I don't know how to capture tpg images and save them into memory as files.
I want your help , thanks !
