Import xfDNN error
I am using ML suite 1.2 and I got a error message when I want to import xfDNN in python: The key error message is :
ImportError: /ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/caffe/../../../libcaffe.so.1.0.0: undefined symbol: _ZN6google4base21CheckOpMessageBuilder9NewStringB5cxx11Ev
Please help me to solve this problem.
The whole error message are:
>>> from xfdnn.tools.compile.bin.xfdnn_compiler_caffe import CaffeFrontend as xfdnnCompiler
['/home/jerry/projects/ML-suite/ml-suite-1.2/parallel', '/home/jerry/projects/ML-suite/ml-suite-1.2/bin', '/home/jerry/projects/ML-suite/ml-suite-1.2/version', '/home/jerry/projects/ML-suite/ml-suite-1.2/weights', '/home/jerry/projects/ML-suite/ml-suite-1.2/optimizations', '/home/jerry/projects/ML-suite/ml-suite-1.2/network', '/home/jerry/projects/ML-suite/ml-suite-1.2/memory', '/home/jerry/projects/ML-suite/ml-suite-1.2/graph', '/home/jerry/projects/ML-suite/ml-suite-1.2/codegeneration', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../weights', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../tests', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../docs', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../codegeneration', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../network', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../version', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../bin', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../pickle', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../frontends', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../graph', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../optimizations', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../fpga_definition', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../parallel', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin/../memory', '', '/home/jerry/projects/ML-suite/ml-suite-1.2', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/rt', '/home/jerry/projects/ML-suite/ml-suite-1.2/ext', '/home/jerry/projects/ML-suite/ml-suite-1.2/apps/yolo', '/home/jerry/projects/ML-suite/ml-suite-1.2/apps/yolo/nms', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/emu', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/network', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/graph', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/optimizations', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/codegeneration', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/memory', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/version', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/weights', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/bin', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfdnn/tools/compile/parallel', '/home/jerry/projects/ML-suite/ml-suite-1.2/xfmlp/python', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python27.zip', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/plat-linux2', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/lib-tk', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/lib-old', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/lib-dynload', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages', '/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/pydot_ng-1.0.1.dev0-py2.7.egg']
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "./xfdnn/tools/compile/bin/xfdnn_compiler_caffe.py", line 53, in <module>
File "/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/caffe/__init__.py", line 1, in <module>
from .pycaffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, RMSPropSolver, AdaDeltaSolver, AdamSolver, NCCL, Timer
File "/ap/anaconda2/5.1.0/envs/ml-suite/lib/python2.7/site-packages/caffe/pycaffe.py", line 13, in <module>
from ._caffe import Net, SGDSolver, NesterovSolver, AdaGradSolver, \
Observer durga_bhavani
Re: Import xfDNN error
The issue may be due to Environment not set
$ export XFDNN_ROOT=/ml-suite/xfdnn
$ export MLSUITE_ROOT=/ml-suite
I reinstall an anaconda virtual environment. This problem had been solved.
