Observer durga_bhavani
Not able to run ml-suite on 1525 card
I am trying to do the following steps after ml-suite setup:
$ cd ml-suite/examples/classification
$ ./run.sh -p 1525 -t test_classify -k med -b 16
I am getting the following error:
Loading weights/bias/quant_params to FPGA...
ERROR: Failed to allocate A device memory
python: xblas.cpp:3163: void xblasLoadA(XBLASHandle&, int, const void*, const char*, XBLASConfig*, int): Assertion `ret' failed.
./run.sh: line 136: 31701 Aborted (core dumped) python test_classify.py --xclbin $XCLBIN_PATH/$XCLBIN --netcfg ./data/${MODEL}_${DSP_WIDTH}.json --fpgaoutsz $FPGAOUTSZ --datadir ./data/${MODEL}_data --labels ./synset_words.txt --xlnxlib $LIBXDNN_PATH --quantizecfg ./data/${MODEL}_${BITWIDTH}b.json --firstfpgalayer $FLAYER --images dog.jpg --PE $ACCELERATOR
Re: Not able to run ml-suite on 1525 card
Hi, Which version of the ml suite are you using right now? thanks, kamran
/k
Hi @kamrank,
I am using master branch of mlsuite.
Now, i am able to run the image classification.
I got the output as below, but whatever the input, the output of the image classification is same.
output:
make: Entering directory `/home/xpac/ml-suite/apps/yolo/nms'
cd ./nms_20180209 && make
make[1]: Entering directory `/home/xpac/ml-suite/apps/yolo/nms/nms_20180209'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/xpac/ml-suite/apps/yolo/nms/nms_20180209'
make: Leaving directory `/home/xpac/ml-suite/apps/yolo/nms'
Running:
Test: test_classify
Model: resnet50
Fpgaoutsz: 2048
Platform: 1525
Xclbin: overlay_1.xclbin
Kernel Config: med
Precision: 16
Accelerator: 0
[XBLAS] # kernels: 1
Linux:3.10.0-693.el7.x86_64:#1 SMP Tue Aug 22 21:09:27 UTC 2017:x86_64
Distribution: CentOS Linux release 7.4.1708 (Core)
GLIBC: 2.17
XILINX_OPENCL="/home/xpac/ml-suite/overlaybins/1525"
LD_LIBRARY_PATH="/home/xpac/ml-suite/overlaybins/1525/runtime/lib/x86_64/:/home/xpac/ml-suite/xfdnn/rt/xdnn_cpp/build/lib:/home/xpac/ml-suite/xfdnn/rt/lib:/home/xpac/ml-suite/ext/boost/lib:/home/xpac/ml-suite/ext/zmq/libs:/home/xpac/ml-suite/examples/classification"
CL_PLATFORM_VENDOR Xilinx
CL_PLATFORM_NAME Xilinx
CL_DEVICE_0: 0x1c97520
CL_DEVICE_1: 0x1c98e90
CL_DEVICES_FOUND 2, using 0
loading /home/xpac/ml-suite/overlaybins/1525/overlay_1.xclbin
[XBLAS] kernel0: kernelSxdnn_0
[XDNN] loading xclbin settings from /home/xpac/ml-suite/overlaybins/1525/overlay_1.xclbin.json
[XDNN] using custom DDR banks 2,2,1,1
[XDNN] kernel configuration
[XDNN] num cores : 2
[XDNN] dsp array width : 28
[XDNN] img mem size : 4 MB
[XDNN] version : 2.2
[XDNN] 8-bit mode : 0
[XDNN] Max Image W/H : 1023
[XDNN] Max Image Depth : 4095
[XDNN] Max Filter Depth : 0
After FPGA (20078.809977 ms)
After FC (1.541138 ms)
After Softmax (0.437975 ms)
---------- Prediction 0/0 for dog.jpg ----------
0.0010 - "n03657121 lens cap, lens cover"
0.0010 - "n07615774 ice lolly, lolly, lollipop, popsicle"
0.0010 - "n04356056 sunglasses, dark glasses, shades"
0.0010 - "n04597913 wooden spoon"
0.0010 - "n03759954 microphone, mike"
Success!
