Quantize issue in ml-suite for caffe
I cloned recent ml-suite and try to use api quantize.pyc. I use this code for a try.
MLSUITE_ROOT=/ml-suite
for BITWIDTH in 16 8; do
    python $MLSUITE_ROOT/xfdnn/tools/quantize/quantize.py \
        --deploy_model $MLSUITE_ROOT/models/caffe/resnet/fp32/resnet50_without_bn_deploy.prototxt \
        --output_json $MLSUITE_ROOT/examples/quantize/work/caffe/resnet/resnet50_without_bn_quantized_int${BITWIDTH}_deploy.json \
        --weights $MLSUITE_ROOT/models/caffe/resnet/fp32/resnet50_without_bn.caffemodel \
        --calibration_directory $MLSUITE_ROOT/models/data/ilsvrc12/ilsvrc12_img_cal \
        --calibration_size 32 \
        --bitwidths ${BITWIDTH},${BITWIDTH},${BITWIDTH} \
        --dims 3,224,224 \
        --transpose 2,0,1 \
        --channel_swap 2,1,0 \
        --raw_scale 255.0 \
        --mean_value 104.0,117.0,123.0 \
        --input_scale 1.0
This step is throwing error as follow:
Processing layer 0 of 139
Layer Name:input Type:Input
('Inputs:', '[], Outputs:', "['data']")
Quantizing layer output...
('Min: ', 0, ', Max: ', 151.0)
('n: ', 128, ', len(bin_edges): ', 2196)
('Mean : th_layer_out: ', 151.03439635535307, ', sf_layer_out: ', 1.1892472153964808)
('bw_layer_out: ', 8)
('th_layer_out: ', 151.03439635535307)
Processing layer 1 of 139
Layer Name:conv1 Type:Convolution
('Inputs:', "['data'], Outputs:", "['conv1']")
('Quantizing conv input layer ...', 'conv1')
Traceback (most recent call last):
  File "/home/local/ZOHOCORP/durga-7043/ml-suite/xfdnn/tools/quantize/quantize.py", line 207, in <module>
    quantizer.quantize()
  File "/home/local/ZOHOCORP/durga-7043/ml-suite/xfdnn/tools/quantize/quantize.py", line 96, in quantize
    quant_layers = caffeObj.executeCalibration(bitwidths, self.deploy_model, quant_params)
  File "./xfdnn/tools/quantize/quantize_caffe.py", line 101, in executeCalibration
  File "./xfdnn/tools/quantize/quantize_caffe.py", line 213, in preProcess
KeyError: 'data'
For clear description of above error please go through the following txt file
Visitor sairahul321
Re: Quantize issue in ml-suite for caffe
I have similar issue with the resnet101 and resnet152 model, but my resnet50 model quantized fine.
resnet101-->
Processing layer 0 of 483
Inputs: [], Outputs: ['data']
Min:  0 , Max:  151.0
n:  128 , len(bin_edges):  1099
Mean : th_layer_out:  151.06876138433515 , sf_layer_out:  1.1895178061758673
bw_layer_out:  8
Processing layer 1 of 483
Inputs: ['data'], Outputs: ['conv1']
Quantizing conv input layer ... conv1
  File "./xfdnn/tools/quantize/quantize.py", line 239, in <module>
  File "./xfdnn/tools/quantize/quantize.py", line 157, in quantize
  File "./xfdnn/tools/quantize/quantize_caffe.py", line 110, in executeCalibration
  File "./xfdnn/tools/quantize/quantize_caffe.py", line 222, in preProcess
KeyError: 'data'
resnet152-->
Processing layer 0 of 721
Min:  0 , Max:  151.0
n:  128 , len(bin_edges):  2196
Mean : th_layer_out:  151.03439635535307 , sf_layer_out:  1.1892472153964808
bw_layer_out:  8
Processing layer 1 of 721
KeyError: 'data'
Visitor sairahul321
resnet101-->
Min:  0 , Max:  151.0
bw_layer_out:  8
KeyError: 'data'
resnet152-->
Min:  0 , Max:  151.0
bw_layer_out:  8
KeyError: 'data'
Visitor sairahul321
I think I might have found the solution to my resnet 101 and 152 issue. I compared working resnet 50 prototxt file with 101 and 152 models and found the input layer is represented differently. Once I made the change quantization is working fine.
Working setup
layer {
  type: "Input"
  top: "data"
  input_param {
    shape {
      dim: 1
      dim: 3
      dim: 224
      dim: 224
By default it came like this
input: "data"
input_dim: 1
input_dim: 3
input_dim: 224
input_dim: 224
Thanks for the question and the follow up. The v1.1 caffe quantizer does have a strict requirement that the input layer be named “data”. This error happens when the caffe layers are loaded, and the quantizer looks for the dimension of the data layer, and can’t find “data”. This has been enhanced in ml-suite v1.2 which is now on the master branch.
Thank you for reply, it's working now.
Visitor zohoraja
Hi Bryanloz,
 We would like to stay with 1.1 because we use VCU1525 (on premises). Moving to 1.2 requires couple of changes in the repo which is difficult to manage at our end. Hence, please let us know how we can change the name of input layer to 'data'.
Also, the repo has only .pyc  files not .py for  compile/quantizer . Please let us know the source files for the same. It would be easier for us extend/customise for our use. We have no plans to outsource or external use. It is solely for internal purposes only.
Raja
