Visitor ap-nsg
Tensorflow quantize - missing scripts/tools/documentation AWS Xilinx ML Suite (f1.2xlarge)
I recently launched the AWS Xilinx ML Suite (f1.2xlarge) and tried the entire cycle as described in your webminar demo with bvlc_googlenet using the tensorflow framework. I succeeded with the loading of the tensorflow docker container as well as the compiler stage but I couldn't find the tools/script for the tensorflow quantize. (for example your webminar demo includes the file classify_pb.py)
Nevertheless, I couldn't find detailed documentation for a quantize stage of a tensforflow graph. It is very much different from other frameworks.
Am I missing something?
Thanks!
Re: Tensorflow quantize - missing scripts/tools/documentation AWS Xilinx ML Suite (f1.2xlarge)
Visitor ap-nsg
Thanks for the quick response, however I tried the quantize.pyc with your googlenet tensorflow .pb model (bvlc_googlenet_without_lrn_test.pb) and and its asks for a caffe module:
Traceback (most recent call last):
File "./xfdnn/tools/quantize/quantize.py", line 43, in <module>
File "./xfdnn/tools/quantize/quantize_caffe.py", line 29, in <module>
ImportError: No module named caffe
I am trying to test the entire cycle from compile through quantize to deployment with goooglenetv1 but the quantize phase doesn't work and the documentation is not clear, it is geared toward caffe.
Can you give the short script for running the quantize within your tensorflow docker container and googlenetv1.
I have tried all kind of options with quantize.pyc as well as quantize_tf.pyc and it doesn't seams to work!
Hi ap-nsg,
My fault. Please use quantize_tf.pyc on https://github.com/Xilinx/ml-suite/tree/master/xfdnn/tools/quantize.
"_tf" stands for Tensorflow.
All available docs is here https://github.com/Xilinx/ml-suite/tree/master/docs
Visitor ap-nsg
Hi jishuaiz,
Thanks again for your quick response. However, it looks like that something is missing for the tensorflow quantize stage.
Again, I am following the instruction on the Quantization tutorial using your GooglenetV1 example but with tensorflow:
1. I am connecting to F1
2. navigating to the tensorflow docker
3. starting the docker successfuly
4. exporting the root in the enviorment
5. navigating to the quantize directory
6. running the quantize_tf.pyc with a "bvlc_googlenet.pb" model (be aware its a .pb file) and all type of arguments.
the python code does nothing. I have tried different arguments ...
BTW, as said in the original message, The compile part of the example with tensorflow was successful. However the quantize! .
Can somebody test your quantize example with GooglenetV1 and post the few line script and instructions.
Again, I am trying to test the xfdnn through all stages up to deployment with tensorflow and googlenetv1 example.
Hi ap-nsg
Thanks. I will contact the developer and back to you later.
Any updates on this issue? quantize_tf.pyc does nothing when I run it on local linux machine.
quantize_tf.pyc does nothing when I run it with command as follows
python quantize_tf.py --model_file ../../../models/tensorflow/resnet/fp32/resnet50_without_bn_test.pb --quantize_config quantize.json --cal_dir calibration_directory/ --cal_size 1 --bitwidths 8,8,8
Hi Weizhong, Durga,
There is update for tensorflow flow. Please follow this linker , https://github.com/Xilinx/ml-suite/blob/v1.2/notebooks/image_classification_tensorflow.ipynb .
Visitor eensafi
I am using the latest ML Suite v1.3 from GitHub.  Like the original post, it is still unclear whether we should be running quantize.pyc or quantize_tf.pyc.  Each fails in a different way:
1. quantize.pyc - Some parameter is "None" but I cannot figure out what to specify on the command-line to make it happy.  I have tried the following with --calibration_directory and many other command-line options, and the error is always the same:
python /opt/xilinx/ml-suite/xfdnn/tools/quantize/quantize.pyc --deploy_model model_tf.pb --output_json output.json
File "./xfdnn/tools/quantize/quantize.py", line 219, in <module>
File "/home/eensafi/.conda/envs/ml-suite/lib/python2.7/genericpath.py", line 37, in isfile
st = os.stat(path)
TypeError: coercing to Unicode: need string or buffer, NoneType found
2. quantize_tf.pyc - Does not work due to a package import error, even in the simplest case:
python /opt/xilinx/ml-suite/xfdnn/tools/quantize/quantize_tf.pyc --help
File "./xfdnn/tools/quantize/quantize_tf.py", line 22, in <module>
ValueError: Attempted relative import in non-package
I have a problem with qunatize_tf.pyc, not able to run on command line, where as able to run in notebook.
regards,
V Durga.
Visitor eensafi
Durga: I am assuming that in a notebook, you are calling the Python API, which is different from trying to run quantize_tf.pyc at the command-line as a __main__  script.
There is also quantize_caffe.pyc, which does nothing if executed on its own, but it does not suffer from the same package import error as quantize_tf.pyc.  This led me to believe that the correct top-level driver is quantize.pyc, which will then invoke the "tf" or "caffe" version depending on the input file types.  Is this a correct assessment?  If so, we go back to the first error related to a parameter being "None" and not knowing how to fix it.
Visitor mahinlman
Updated the quantization script for Tensorflow - ml-suite_Tensorflow_Quantization
Follow this doc for using quantize.pyc
If you facing any issues/errors, then please let me know.
Mahi
Visitor eensafi
Thank you for your reply.  I finally got the quantizer to run using the Python API, not the standalone script, but it does not produce correct results.  Apparently, the ML Suite TensorFlow quantizer is broken.  Does the updated script address the quantization bugs or just the execution issues?
Visitor mahinlman
Actually, quantize.pyc in ml-suite only has caffe related initialization scripts.
Now I have updated quantize.pyc with Tensorflow quantize script. with that I'm able to get quantization results.
Today only, I have pull request to ml-suite.
