ml-suite v1.2: ImportError: No module named tools
I've installed the ml-suite v1.2 (master branch) following the "Getting Started" guide (https://github.com/Xilinx/ml-suite/blob/master/README.md)
I cannot compile any deep learning networks, also the ones provided with example designs, because I got the following error: "ImportError: No module named tools". Could you please help me on this ?
This is the log:
python xfdnn/tools/compile/bin/xfdnn_compiler_caffe.pyc -n models/caffe/bvlc_googlenet_quantized/GoogleNetWithOutLRN_dummydata_deploy.prototxt -s all -m 4 -i 28 -g network.cmd -w models/bvlc_googlenet_without_lrn/fp32/bvlc_googlenet_without_lrn.caffemodel
['/home/username/ml-suite/xfdnn/tools/compile/bin/parallel', '/home/username/ml-suite/xfdnn/tools/compile/bin/bin', '/home/username/ml-suite/xfdnn/tools/compile/bin/version', '/home/username/ml-suite/xfdnn/tools/compile/bin/weights', '/home/username/ml-suite/xfdnn/tools/compile/bin/optimizations', '/home/username/ml-suite/xfdnn/tools/compile/bin/network', '/home/username/ml-suite/xfdnn/tools/compile/bin/memory', '/home/username/ml-suite/xfdnn/tools/compile/bin/graph', '/home/username/ml-suite/xfdnn/tools/compile/bin/codegeneration', '/home/username/ml-suite/xfdnn/tools/compile/bin', '/home/username/anaconda2/envs/ml-suite/lib/python27.zip', '/home/username/anaconda2/envs/ml-suite/lib/python2.7', '/home/username/anaconda2/envs/ml-suite/lib/python2.7/plat-linux2', '/home/username/anaconda2/envs/ml-suite/lib/python2.7/lib-tk', '/home/username/anaconda2/envs/ml-suite/lib/python2.7/lib-old', '/home/username/anaconda2/envs/ml-suite/lib/python2.7/lib-dynload', '/home/username/.local/lib/python2.7/site-packages', '/home/username/anaconda2/envs/ml-suite/lib/python2.7/site-packages', '/home/username/anaconda2/envs/ml-suite/lib/python2.7/site-packages/pydot_ng-1.0.1.dev0-py2.7.egg']
Traceback (most recent call last):
File "./xfdnn/tools/compile/bin/xfdnn_compiler_caffe.py", line 62, in <module>
Thank you,
Andrea
Re: ml-suite v1.2: ImportError: No module named tools
before compiling the model, just go through the following step
$ cd /ml-suite/
$ source ./overlaybins/setup.sh
now check compiling the model
$ cd /ml-suite/
Thank you, this solved the problem.
