Cannot get USB to work on microzed 7010 with arch linux using 2015.2 tools
I'm building using Vivado 2015.2, linux-xlnx repo on tag xilinx-v2015.2.01, SDK 2015.2.  I'm trying to get USB to work on my microzed 7010.
When I boot into linux,
no USB devices are recognized
there is no /dev/bus (let alone /dev/bus/usb)
/sys/bus/usb/ exists
nothing in /sys/bus/usb/devices/
/proc/device-tree/amba/usb@e0002000 exists
After setting LIBUSB_DEBUG=9
lsusb returns:
libusb: debug [libusb_init] created default context
libusb: debug [libusb_init] libusb v1.0.19.10903
libusb: error [op_init] could not find usbfs
unable to initialize libusb: -99
dmesg | grep -i usb returns:
[    0.320762] usbcore: registered new interface driver usbfs
[    0.320847] usbcore: registered new interface driver hub
[    0.320943] usbcore: registered new device driver usb
[    1.033036] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.041452] usbcore: registered new interface driver cdc_acm
[    1.045737] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.052499] usbcore: registered new interface driver usb-storage
[    1.057338] e0002000.usb supply vbus not found, using dummy regulator
[    1.168681] usbcore: registered new interface driver usbhid
[    1.172882] usbhid: USB HID core driver
my zynq-7000.dtsi contains:
		usb0: usb@e0002000 {
			compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
			status = "disabled";
			clocks = <&clkc 28>;
			interrupt-parent = <&intc>;
			interrupts = <0 21 4>;
			reg = <0xe0002000 0x1000>;
			phy_type = "ulpi";
my system.dts contains:
&usb0 {
	dr_mode = "host";
	phy_type = "ulpi";
	status = "okay";
	usb-reset = <&gpio0 7 0>;
Is there something I'm missing?
I attempted to follow http://www.wiki.xilinx.com/Zynq+Linux+USB+Device+Driver but to no avail.
Re: Cannot get USB to work on microzed 7010 with arch linux using 2015.2 tools
try to use older usb driver: compatible = "xlnx,ps7-usb-1.00.a", "xlnx,zynq-usb-1.00.a";
It was the solution for me in similar problem.
Igor
Hi Igor,
Thanks for the suggestion, but that didn't help.  I still do not get any usb devices showing up in /dev. lsusb still gives the -99 error.
I also tried the suggestion at this page: http://stackoverflow.com/questions/25793399/mount-usbfs-on-linux-3-10-kernel
Which was to mount /sys/bus/ to /dev/bus/  but that did not work either.  lsusb returned (instead of erroring out), but it returned nothing, and no devices are detected when I plug them in.
the output of 'dmesg | grep -i usb' is exactly the same as before.
Any other suggestions?
I got it to work by doing the following:
I checked out the xilinx-v2014.2.01 tag in the linux-xlnx repo.  This repo has the kernel version 3.14.0 instead of the 3.19.0 version in the xilinx-v2015.2 tag.
Once I rebuilt the kernel, the USB started working.
I would love to get USB working on the newest kernel, so all suggestions are welcome, and I will try them and report back.
With the latest drivers you also need to specify the USB phy in the device tree.
My dts for a 4.0 kernel looks like this:
&ps7_usb_1 {
	status = "okay";
	usb-phy = <&usb_phy1>;
usb_phy1: usb-phy@1 {
	compatible = "usb-nop-xceiv";
	status = "okay";
Why would Xilinx break a working system? I have exactly this problem right now, and it seems so needless. Why would the a.) Take a big step backwards by breaking something that was working. And then:
b.) Not document the change, warn users, or really do anything to fix a HUGE problem like non-working USB?
Tried the instructions on:
and it still does not work at all. It seems like the bus is not getting power.
