Problem using two uarts with a Zynq First Stage Boot Loader BSP. SDK 2014.2
Accepted Solution Solved
Accepted Solution
We need to use both uart ports in order to communicate with a H-bridge and send data to the computer.
Everything was working fine but, in order to save the program in the QSPI flash memory and not to program the ARM every time we need to run a test, we follow the Xilinx University Program Advanced embedded tutorial (#5) and we make a Zynq FSBL (First stage bootloader) BSP. But using this BSP and debugging we don't get any data on the terminal (if we eliminate the UART0 in vivado we can receive data but if we activate both UARTS we get nothing).
We already make another project, recheck the xparameters.h constant names, but every time we activate both uarts we stop to receive data, even when the program appears to be running.
We are out of ideas. Any advice? Anyone experience this problem?
We are using Vivado and SDK 2014.2
Re: Problem using two uarts with a Zynq First Stage Boot Loader BSP. SDK 2014.2
Can you cross verify if the stdin/stdout  bsp settings are set to uart1?
Achutha
All Replies
UART1 it's mapped to MIO 48 and 49 (as default)
UART0 it's mapped to
MIO 10          PMOD JF2             RX
MIO 11          PMOD JF3             TX
We are using a Zybo, by the way.
Achutha
debug as
you will see in debugger what uart is used or where progam gets stuck
we are porting arduino library to zynq
http://youtu.be/QYmZovrErwY
as soon as we add the UART support.. well comes soon :)
That was it! We ended up discovering it in the morning and when I went to post the solution I see your response. Thanks a lot achutha.
This project looks amazing! I'll be pending and good luck with that!
