pl.dsti file
pl.dsti file
We are using 2015.2 Vivado/petalinx on ubuntu, our hardware engineer created .hdf file, and I took this file to create petalinx project and after doing petalinx-config, pl.dsti was created, but only shows leds_4bits: gpio@41200000 instead of 4bits, I can see from the files after .hdf unzip, there was 8bit leds there, anybody knows what's wrong with it?
We are using Zedboard.
Re: pl.dsti file
leds_4bits is just a label it doesn't necessarily mean it only has 4 bits.   How was the GPIO controller configured?  If it was for more than 4 gpios then it should work.  Did you trying using it with something like devmem?
jeff
Re: pl.dsti file
Hi, Jeff
Thanks for the reply, no I didn't use memdev, what is it for? The following is from .tcl file which was created
by Vivado, I noticed that there are label inconsistency for 8bits leds gpio pin:
# Create interface ports
set leds_8bits [ create_bd_intf_port -mode Master -vlnv xilinx.com:interface:gpio_rtl:1.0 leds_8bits ]
# Create instance
set leds_8bits [ create_bd_cell -type ip -vlnv xilinx.com:ip:axi_gpio:2.0 leds_8bits ]
set_property -dict [ list CONFIG.C_ALL_INPUTS {0} CONFIG.C_ALL_OUTPUTS {1} CONFIG.C_GPIO_WIDTH {8} CONFIG.GPIO_BOARD_INTERFACE {leds_8bits} CONFIG.USE_BOARD_FLOW {true} ] $leds_8bits
# Create interface connections
connect_bd_intf_net -intf_net axi_gpio_0_GPIO [get_bd_intf_ports leds_8bits] [get_bd_intf_pins leds_8bits/GPIO]
# Create port connections
connect_bd_net -net processing_system7_0_FCLK_CLK0 [get_bd_pins axi_bram_ctrl_0/s_axi_aclk] [get_bd_pins axi_gpio_1/s_axi_aclk] [get_bd_pins axi_mem_intercon/ACLK] [get_bd_pins axi_mem_intercon/M00_ACLK] [get_bd_pins axi_mem_intercon/M01_ACLK] [get_bd_pins axi_mem_intercon/M02_ACLK] [get_bd_pins axi_mem_intercon/S00_ACLK] [get_bd_pins leds_8bits/s_axi_aclk] [get_bd_pins processing_system7_0/FCLK_CLK0] [get_bd_pins processing_system7_0/M_AXI_GP0_ACLK] [get_bd_pins rst_processing_system7_0_100M/slowest_sync_clk]
# Create address segments
create_bd_addr_seg -range 0x10000 -offset 0x41200000 [get_bd_addr_spaces processing_system7_0/Data] [get_bd_addr_segs leds_8bits/S_AXI/Reg] SEG_axi_gpio_0_Reg
That could be the reason it failed. I saw there is gpiochip created when petalinx boot up, just I won't be able to modify the value to on/off the leds.
Re: pl.dsti file
 devmem is a tool on linux that lets you read/write to physical address.  So you can just provide the register address of the gpio controller and program it that way for simple testing.    I can't really provide any input on your tcl file.
jeff
