Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
0
Accepted Solution
EDK 10.1 SP2 & Chipscope
 I had a design compiled fine with EDK 10.1 SP1. With EDK 10.1 SP2, I've got the following error message.
Running synthesis...
bash -c "cd synthesis; ./synthesis.sh"
xst -ifn system_xst.scr -intstyle silent
Running XST synthesis ...
ERROR:Xst:1617 - Processing TIMESPEC TS_U_TO_D: user TIMEGRP 'D_CLK' must be previously defined in FROM/TO constraint.
ERROR:Xst:1489 - Constraint annotation failed.
make: *** [implementation/system.ngc] Error 1
ERROR:MDT - Error while running "make -f system.make netlist"
No changes to be saved in MSS file
No changes to be saved in XMP file
ERROR: synthesizing XPS module failed!
Process "XPS Process: Synthesize XPS Source" failed
Note : my design have a system.xmp instantiated in the top vhdl source file. This system.xmp contains an chipscope icon, with control0 as an external port : I want to use chipscope to debug my vhdl design AND use xmd (target is Spartan3A).
In fact, Xilinx software produced a wrong ncf file with wrong timespec
I think that is fairly common approach and I'm almost surprised not to see similar message in the forum
I 've already open a webcase for this (big) bug (first time, for many years I used Xilinx software, I need to go back to a previous SP…). The solution was to go back to SP1.
I'm a bit worry because I see no answer record concerning it. Is there any patch ? other solution ? or, a least, is it solved in EDK SP3 ?
Thanks in advance for your response.
Best regards.
Expert Contributor
0
Re: EDK 10.1 SP2 & Chipscope
 Don't mean to get Xilinx off the hook for problems with synthesizing your Chipscope components however there is another way to use
chipscope which may avoid these problems described.
There is a alternative approach to using chipscope with EDK that has worked for me with a Virtex 5 chip.
You can try this if you want I recommend theses links.
http://www.xilinx.com/support/documentation/ip_documentation/ug241.pdf
http://forums.xilinx.com/xlnx/board/message?board.id=EDK&message.id=2795#M2795
http://www.xilinx.com/support/answers/19423.htm
especially the 19423 link.
In a nutshell here is a simplified procedure:
Go to the menu and select hardware -> generate netlists
After the netlist has been built then type
go into the implementation directory and type
ngcbuild -i system.ngc system_all.ngc
after ngcbuild has completed then bring up Chipscope inserter:
have the input selected as system_all.ngc
and the output selected as system.ngc
 Make sure you disable RPM radio button.  and you choose the correct type of Chip family such as virtex 5.
Then accept these changes by selecting next or whatever.
Then configure your chipscope  selecting signals and clock and how many signals for the ILA ect.
After configured.  Save your CDC file with a arbitrary name and allow chipscope inserter to run through.
It will insert the ILA ect into your design.
After ILA has been added to the design by chipscope inserter.
Do the following:
Hardware -> Generate Bitstream
After bitstream has been generated.
Download to the Board the bitstream
Bring up XMD download and connect the application software to the board
So that the microblaze is up and running
Bring up Chipscope analyzer (a different software)
Connect Cable that is get JTAG communication with board running.
Start Using Chipscope.
This procedure is illustrated at
0
Thanks you for your long answer. I will examined it in details. I use system.xmp with ISE (instanciated component), so I will read your hyperlink if I can adapt it to ISE.
However... I'd prefered not use core inserter, simply use what I've done with ISE 10.1 SP1 (and ISE 10.1, 9.2 with all SP) ! So I greatly appreciated to have a Xilinx answer told me that this bug has been solved.
Regards.
0
I would recommend opening a webcase as it is hard to tell with out looking at the files what the problem might be...
0
Thanks for your answer. I've already open a Webcase for this problem, as I wrote in the first post. It has been "closed" with the solution to go back to SP1. However, I hope Xilinx people works to solve this bug. This is the aim of this thread.
Regards.
0
[ Edited ]
Can you post your project or a test project on the FTP site and post the name of the zip file here:
http://www.xilinx.com/support/answers/1368.htm
I can then see what is going on...
Message Edited by chadn on 08-18-2008 07:59 AM
0
Thanks taking into account this problem.
I've upload a project showing this problem. The name is "ML505_MB_XMK_10_1.zip", 2Mo. This project came from a Xilinx example and I've just add Chipscope icon IP with "control0" as an external port. This project (ML505_MB_XMK_10_1.zip) works fine with EDK SP1 but fails with EDK SP2. The message is:
Note: I've used FireFTP and I've the following message (I can't see my file, I repeat the steps many times and hope the file was, in fact upload...).
227 Entering Passive Mode (63,241,181,136,128,22)
       STOR ML505_MB_XMK_10_1.zip
150 Ok to send data.
226 File receive OK.
       TYPE A
200 Switching to ASCII mode.
       PASV
227 Entering Passive Mode (63,241,181,136,128,24)
       LIST
150 Here comes the directory listing.
226 Transfer done (but failed to open directory).
       NOOP
200 NOOP ok.
Best regards.
0
[ Edited ]
If you look in the following folder you will find an ncf file, these constraints are getting added to the Chipscope core.  XST is correct in erroring out since you do not have a D_CLK group defined.  The D_CLK group is typically defined in a ILA or IBA core.
$PROJECT_NAME\implementation\chipscope_icon_0_wrapper
I compared the differences between 10.1.01i and 10.1.02i and traced it the following line in the Chipscope tcl file:
# exec rm -f [file nativename [pwd]]/implementation/$params(INSTANCE)_wrapper/$params(INSTANCE).ncf
The file can be found at:
$XILINX_EDK\hw\XilinxProcessorIPLib\pcores\chipscope_icon_v1_02_a\data
Basically the ncf file is not getting added to the folder above in 10.1.01 (this line is uncommented in 10.1.01i and commented in 10.1.02i), hence you were not seeing this error in 10.1.01i.
You have three options:
uncomment this line in the tcl (so ncf file is not added)
add an ILA or IBA to your EDK project (will add d_clk group)
Move the ICON core to your ISE project
Is there a particular reason why you are adding the ICON to the EDK project if you are attaching to it in your ISE portion?  I am not sure why that line was changed (uncommented/commented) but I think typically is was expected that if you were using the ICON core in EDK you would be using an ILA, IBA, or VIO so the D_CLK would be defined.
Message Edited by chadn on 08-18-2008 01:05 PM
0
After you reading your initial description I can see why you are including ICON in EDK.
If you have one BSCAN block (ie S3, V2P, and other devices), including the ICON in EDK can make it easier because you do not need to port the JTAG signals from the ISE portion to the EDK portion (since EDK will automatically hook up the JTAG signals from the ICON to the MDM).  I have filed a CR so developers are aware of this...
However, if you are using V-5 device which has multiple BSCAN blocks I do not really see any advantages of including the ICON block in the EDK portion of the design and would recommend you move it the ISE portion.
0
Thanks you very much for this solution, Now it's work ! I will try today on my original design and tell you if it's ok (probably yes)
Strange to see on the line above :
## TODO : See what the NCF error is
Anyway, yes my target is Spartan-3A and I want to use mdm to download my software and use Chipscope ila core in my vhdl design to debug logic.
I remember, in previous release of ISE (and without EDK), sometimes, I've got same kind of problem with the generated ncf file (from Chipscope Generator) and
I deleted it manually and it worked. Here, I've also try to delete manually ncf file in \implementation\chipscope_icon_0_wrapper but it wasn't work.
Thanks again for your support (I can re-install EDK SP2) and filling an CR.
Best regards.
