Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Contributor
0
Accepted Solution
RAMDISK: Compressed image found at block 0 ?
I'm newbie in Xilinx Linux flow and try to run Linux in the Avnet FX12 mini module on the current kernel sources.
I worked based on instructions found on http://xilinx.wikidot.com.
I started which the  configuration make ARCH=powerpc 40x/virtex4_defconfig and enabled the console kernel output.
I built an simpleImage.initrd.virtex405-FX12mini.elf and loaded this file into the module via XMD.
The bootloader starts but stopps or crashes after the message: RAMDISK: Compressed image found at block 0 .
So I tried several ramdisk.image.gz I found on http://xilinx.wikidot.com, in the forum and ELDK images. The images seems to be good.
It seems to me the kernel file system isn't configured or not found in the memory.
Does a solution exsists?
Or where should I start to fix the problem?
Best regards,
Thomas
Regular Contributor
0
Re: RAMDISK: Compressed image found at block 0 ?
Hallo,
I traced a little bit into the kernelsource.
I found in do_mounts_rd.c that the the program jumps decompressor "gunzip" but never returns.
May be I have a problem in my kernel configuration?
Regards, Thomas
Expert Contributor
0
Hi Thomas,
Did it really crash?  Can you put in the console output?
I just wanted to make sure if it did crash or the console output just stopped which are different.
You didn't give any details, but the console should have been enabled in the kernel config I think such that you should not have had to do anything?
Are you using Uart Lite or 550?
The default kernel config you used should have worked for the ram disk I think.  The ramdisk is usually turned on in the default kernel config and it did find the ramdisk.
Have you reviewed the kernel debug page on the wiki also?
John
Regular Contributor
0
Hello John,
thanks for reply.
After the line "RAMDISK: gzip image found at block 0" the output stops.
I traced into I saw in do_mounts_rd.c that the the program jumps decompressor "gunzip" but never returns.
Probably a simple but general problem in my configuration?
I attached the console output, dts, .config and MHS file.
John, please have a look at my "configs". Thanks in advance.
Best regards,
Thomas
This console output  I got:
zImage starting: loaded at 0x00400000 (sp: 0x006ffeb0)
Allocating 0x35732c bytes for kernel ...
gunzipping (0x00000000 <- 0x0040c000:0x0058e4a0)...done 0x337df4 bytes
Attached initrd image at 0x0058f000-0x006fef20
initrd head: 0x1f8b0808
Linux/PowerPC load: console=ttyUL0,115200 root=/dev/ram
Finalizing device tree... flat tree at 0x70c300
Using Xilinx Virtex machine description
Linux version 2.6.30 (root@bagvapp) (gcc version 4.2.2) #5 PREEMPT Tue Sep 29 20
:16:58 CEST 2009
Found initrd at 0xc058f000:0xc06fef20
Zone PFN ranges:
  DMA      0x00000000 -> 0x00004000
  Normal   0x00004000 -> 0x00004000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00004000
MMU: Allocated 1088 bytes of context maps for 255 contexts
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: console=ttyUL0,115200 root=/dev/ram
NR_IRQS:512
Xilinx intc at 0x81800000 mapped to 0xfddff000
PID hash table entries: 256 (order: 8, 1024 bytes)
clocksource: timebase mult[d55555] shift[22] registered
Console: colour dummy device 80x25
console [ttyUL0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 59984k/65536k available (3148k kernel code, 5492k reserved, 124k data, 1
24k bss, 148k init)
Kernel virtual memory layout:
  * 0xffffe000..0xfffff000  : fixmap
  * 0xfde00000..0xfe000000  : consistent mem
  * 0xfddfe000..0xfde00000  : early ioremap
  * 0xc5000000..0xfddfe000  : vmalloc & ioremap
Calibrating delay loop... 598.01 BogoMIPS (lpj=1196032)
Mount-cache hash table entries: 512
net_namespace: 880 bytes
PCI: Probing PCI hardware
bio: create slab <bio-0> at 0
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 1471k freed
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
ROMFS MTD (C) 2007 Red Hat, Inc.
msgmni has been set to 120
io scheduler noop registered
84000000.serial: ttyUL0 at MMIO 0x84000003 (irq = 0) is a uartlite
brd: module loaded
loop: module loaded
Device Tree Probing 'ethernet'
xilinx_lltemac 81c00000.ethernet: MAC address is now  0: a:35: 0: 0: 0
xilinx_lltemac 81c00000.ethernet: XLlTemac: using DMA mode.
XLlTemac: Dma base address: phy: 0x84600100, virt: 0xc5018100
XLlTemac: buffer descriptor size: 32768 (0x8000)
XLlTemac: Allocating DMA descriptors with kmalloc<6>XLlTemac: (buffer_descriptor
_init) phy: 0x3878000, virt: 0xc3878000, size: 0x8000
XTemac: PHY detected at address 4.
eth0 (xilinx_lltemac): not using net_device_ops yet
xilinx_lltemac 81c00000.ethernet: eth0: Xilinx TEMAC at 0x81C00000 mapped to 0xC
5012000, irq=16
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
TCP cubic registered
system stucks here in "gunzip".
 dts File:
 * Device Tree Generator version: 1.3
 * (C) Copyright 2007-2008 Xilinx, Inc.
 * (C) Copyright 2007-2008 Michal Simek
 * Michal SIMEK <monstr@monstr.eu>
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
 * MA 02111-1307 USA
 * CAUTION: This file is automatically generated by libgen.
 * Version: Xilinx EDK 10.1.03 EDK_K_SP3.6
 * XPS project directory: XPS
/dts-v1/;
    #address-cells = <1>;
    #size-cells = <1>;
    compatible = "xlnx,virtex405", "xlnx,virtex";
    model = "testing";
    DDR_SDRAM_32Mx16: memory@0 {
        device_type = "memory";
        reg = < 0x0 0x4000000 >;
    aliases {
        ethernet0 = &TriMode_MAC_GMII;
        serial0 = &RS232;
    chosen {
        bootargs = "console=ttyUL0,115200 root=/dev/ram";
        linux,stdout-path = "/plb@0/serial@84000000";
    cpus {
        #cpus = <0x1>;
        #size-cells = <0>;
        ppc405_0: cpu@0 {
            clock-frequency = <300000000>;
            compatible = "PowerPC,405", "ibm,ppc405";
            d-cache-line-size = <0x20>;
            d-cache-size = <0x4000>;
            dcr-access-method = "native";
            dcr-controller ;
            device_type = "cpu";
            i-cache-line-size = <0x20>;
            i-cache-size = <0x4000>;
            model = "PowerPC,405";
            reg = <0>;
            timebase-frequency = <300000000>;
            xlnx,apu-control = <0xde00>;
            xlnx,apu-udi-1 = <0xa18983>;
            xlnx,apu-udi-2 = <0xa38983>;
            xlnx,apu-udi-3 = <0xa589c3>;
            xlnx,apu-udi-4 = <0xa789c3>;
            xlnx,apu-udi-5 = <0xa98c03>;
            xlnx,apu-udi-6 = <0xab8c03>;
            xlnx,apu-udi-7 = <0xad8c43>;
            xlnx,apu-udi-8 = <0xaf8c43>;
            xlnx,deterministic-mult = <0x0>;
            xlnx,disable-operand-forwarding = <0x1>;
            xlnx,fastest-plb-clock = "DPLB0";
            xlnx,generate-plb-timespecs = <0x1>;
            xlnx,mmu-enable = <0x1>;
            xlnx,pvr-high = <0x0>;
            xlnx,pvr-low = <0x0>;
    plb: plb@0 {
        #size-cells = <1>;
        compatible = "xlnx,plb-v46-1.03.a", "xlnx,plb-v46-1.00.a", "simple-bus";
        ranges ;
        RS232: serial@84000000 {
            clock-frequency = <100000000>;
            compatible = "xlnx,xps-uartlite-1.00.a";
            current-speed = <115200>;
            device_type = "serial";
            port-number = <0>;
            reg = < 0x84000000 0x10000 >;
            xlnx,baudrate = <0x1c200>;
            xlnx,data-bits = <0x8>;
            xlnx,family = "virtex4";
            xlnx,odd-parity = <0x0>;
            xlnx,use-parity = <0x0>;
        TriMode_MAC_GMII: xps-ll-temac@81c00000 {
            #size-cells = <1>;
            compatible = "xlnx,compound";
            ethernet@81c00000 {
                compatible = "xlnx,xps-ll-temac-1.01.b", "xlnx,xps-ll-temac-1.00.a";
                device_type = "network";
                interrupt-parent = <&xps_intc_0>;
                interrupts = < 3 2 >;
                llink-connected = <&PIM2>;
                local-mac-address = [ 00 0a 35 00 00 00 ];
                reg = < 0x81c00000 0x40 >;
                xlnx,bus2core-clk-ratio = <0x1>;
                xlnx,phy-type = <0x1>;
                xlnx,phyaddr = <0x1>;
                xlnx,rxcsum = <0x1>;
                xlnx,rxfifo = <0x4000>;
                xlnx,temac-type = <0x1>;
                xlnx,txcsum = <0x1>;
                xlnx,txfifo = <0x2000>;
        mpmc@0 {
            #size-cells = <1>;
            compatible = "xlnx,mpmc-4.03.a";
            PIM2: sdma@84600100 {
                compatible = "xlnx,ll-dma-1.00.a";
                interrupts = < 1 2 0 2 >;
                reg = < 0x84600100 0x80 >;
        xps_intc_0: interrupt-controller@81800000 {
            #interrupt-cells = <0x2>;
            compatible = "xlnx,xps-intc-1.00.a";
            interrupt-controller ;
            reg = < 0x81800000 0x10000 >;
            xlnx,num-intr-inputs = <0x4>;
        xps_timer_1: timer@83c00000 {
            compatible = "xlnx,xps-timer-1.00.a";
            interrupts = < 2 2 >;
            reg = < 0x83c00000 0x10000 >;
            xlnx,count-width = <0x20>;
            xlnx,gen0-assert = <0x1>;
            xlnx,gen1-assert = <0x1>;
            xlnx,one-timer-only = <0x1>;
            xlnx,trig0-assert = <0x1>;
            xlnx,trig1-assert = <0x1>;
    ppc405_0_dplb1: plb@1 {
        #size-cells = <1>;
        ranges ;
Regular Contributor
0
.config file:
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.30
# Tue Sep 29 20:16:20 2009
# CONFIG_PPC64 is not set
# Processor support
# CONFIG_6xx is not set
# CONFIG_PPC_85xx is not set
# CONFIG_PPC_8xx is not set
CONFIG_40x=y
# CONFIG_44x is not set
# CONFIG_E200 is not set
CONFIG_4xx=y
CONFIG_PPC_MMU_NOHASH=y
# CONFIG_PPC_MM_SLICES is not set
CONFIG_NOT_COHERENT_CACHE=y
CONFIG_PPC32=y
CONFIG_WORD_SIZE=32
# CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
CONFIG_MMU=y
CONFIG_GENERIC_CMOS_UPDATE=y
CONFIG_GENERIC_TIME=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_HARDIRQS=y
# CONFIG_HAVE_SETUP_PER_CPU_AREA is not set
CONFIG_IRQ_PER_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_ARCH_HAS_ILOG2_U32=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_GENERIC_FIND_NEXT_BIT=y
# CONFIG_ARCH_NO_VIRT_TO_BUS is not set
CONFIG_PPC=y
CONFIG_EARLY_PRINTK=y
CONFIG_GENERIC_NVRAM=y
CONFIG_SCHED_OMIT_FRAME_POINTER=y
CONFIG_ARCH_MAY_HAVE_PC_FDC=y
CONFIG_PPC_OF=y
CONFIG_OF=y
CONFIG_PPC_UDBG_16550=y
# CONFIG_GENERIC_TBSYNC is not set
CONFIG_AUDIT_ARCH=y
CONFIG_GENERIC_BUG=y
CONFIG_DTC=y
CONFIG_DEFAULT_UIMAGE=y
CONFIG_PPC_DCR_NATIVE=y
CONFIG_PPC_DCR_MMIO=y
CONFIG_PPC_DCR=y
CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
# RCU Subsystem
CONFIG_CLASSIC_RCU=y
# CONFIG_TREE_RCU is not set
# CONFIG_PREEMPT_RCU is not set
# CONFIG_TREE_RCU_TRACE is not set
# CONFIG_PREEMPT_RCU_TRACE is not set
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=14
# CONFIG_GROUP_SCHED is not set
# CONFIG_CGROUPS is not set
CONFIG_SYSFS_DEPRECATED=y
CONFIG_SYSFS_DEPRECATED_V2=y
# CONFIG_RELAY is not set
CONFIG_NAMESPACES=y
# CONFIG_UTS_NS is not set
# CONFIG_IPC_NS is not set
# CONFIG_USER_NS is not set
# CONFIG_PID_NS is not set
# CONFIG_NET_NS is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
# CONFIG_EMBEDDED is not set
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_EXTRA_PASS is not set
# CONFIG_STRIP_ASM_SYMS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_PCI_QUIRKS=y
CONFIG_COMPAT_BRK=y
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
# CONFIG_PROFILING is not set
# CONFIG_MARKERS is not set
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_HAVE_IOREMAP_PROT=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
# CONFIG_SLOW_WORK is not set
# CONFIG_HAVE_GENERIC_DMA_COHERENT is not set
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
CONFIG_MODULE_FORCE_UNLOAD=y
CONFIG_MODVERSIONS=y
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_BLOCK=y
# CONFIG_LBD is not set
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_AS is not set
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
# CONFIG_FREEZER is not set
# CONFIG_PPC4xx_PCI_EXPRESS is not set
# Platform support
# CONFIG_PPC_CELL is not set
# CONFIG_PPC_CELL_NATIVE is not set
# CONFIG_PQ2ADS is not set
# CONFIG_PPC4xx_GPIO is not set
CONFIG_XILINX_VIRTEX=y
# CONFIG_ACADIA is not set
# CONFIG_EP405 is not set
# CONFIG_HCU4 is not set
# CONFIG_KILAUEA is not set
# CONFIG_MAKALU is not set
# CONFIG_WALNUT is not set
CONFIG_XILINX_VIRTEX_GENERIC_BOARD=y
# CONFIG_PPC40x_SIMPLE is not set
CONFIG_XILINX_VIRTEX_II_PRO=y
CONFIG_XILINX_VIRTEX_4_FX=y
CONFIG_IBM405_ERR77=y
CONFIG_IBM405_ERR51=y
# CONFIG_IPIC is not set
# CONFIG_MPIC is not set
# CONFIG_MPIC_WEIRD is not set
# CONFIG_PPC_I8259 is not set
# CONFIG_PPC_RTAS is not set
# CONFIG_MMIO_NVRAM is not set
# CONFIG_PPC_MPC106 is not set
# CONFIG_PPC_970_NAP is not set
# CONFIG_PPC_INDIRECT_IO is not set
# CONFIG_GENERIC_IOMAP is not set
# CONFIG_CPU_FREQ is not set
# CONFIG_FSL_ULI1575 is not set
# CONFIG_SIMPLE_GPIO is not set
# Kernel options
# CONFIG_HIGHMEM is not set
# CONFIG_NO_HZ is not set
# CONFIG_HIGH_RES_TIMERS is not set
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
# CONFIG_HZ_100 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_300 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=250
# CONFIG_SCHED_HRTICK is not set
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
# CONFIG_HAVE_AOUT is not set
# CONFIG_BINFMT_MISC is not set
CONFIG_MATH_EMULATION=y
# CONFIG_IOMMU_HELPER is not set
CONFIG_PPC_NEED_DMA_SYNC_OPS=y
CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
CONFIG_ARCH_HAS_WALK_MEMORY=y
CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_POPULATES_NODE_MAP=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_DISCONTIGMEM_MANUAL is not set
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_MIGRATION=y
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=1
CONFIG_BOUNCE=y
CONFIG_VIRT_TO_BUS=y
CONFIG_UNEVICTABLE_LRU=y
CONFIG_HAVE_MLOCK=y
CONFIG_HAVE_MLOCKED_PAGE_BIT=y
CONFIG_PPC_4K_PAGES=y
# CONFIG_PPC_16K_PAGES is not set
# CONFIG_PPC_64K_PAGES is not set
# CONFIG_PPC_256K_PAGES is not set
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_PROC_DEVICETREE=y
CONFIG_CMDLINE_BOOL=y
CONFIG_CMDLINE=""
CONFIG_EXTRA_TARGETS="simpleImage.virtex405-FX12mm simpleImage.initrd.virtex405-FX12mm"
# CONFIG_PM is not set
CONFIG_SECCOMP=y
# CONFIG_COMPRESSED_DEVICE_TREE is not set
CONFIG_ISA_DMA_API=y
# Bus options
CONFIG_ZONE_DMA=y
CONFIG_PPC_INDIRECT_PCI=y
CONFIG_4xx_SOC=y
CONFIG_PPC_PCI_CHOICE=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCI_SYSCALL=y
# CONFIG_PCIEPORTBUS is not set
CONFIG_ARCH_SUPPORTS_MSI=y
# CONFIG_PCI_MSI is not set
CONFIG_PCI_LEGACY=y
# CONFIG_PCI_STUB is not set
# CONFIG_PCI_IOV is not set
# CONFIG_PCCARD is not set
# CONFIG_HOTPLUG_PCI is not set
# CONFIG_HAS_RAPIDIO is not set
# Advanced setup
# CONFIG_ADVANCED_OPTIONS is not set
# Default settings for advanced configuration options are used
CONFIG_LOWMEM_SIZE=0x30000000
CONFIG_PAGE_OFFSET=0xc0000000
CONFIG_KERNEL_START=0xc0000000
CONFIG_PHYSICAL_START=0x00000000
CONFIG_TASK_SIZE=0xc0000000
CONFIG_CONSISTENT_SIZE=0x00200000
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_MMAP is not set
CONFIG_UNIX=y
CONFIG_XFRM=y
# CONFIG_XFRM_USER is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
# CONFIG_IP_MROUTE is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
CONFIG_INET_TUNNEL=m
CONFIG_INET_XFRM_MODE_TRANSPORT=y
CONFIG_INET_XFRM_MODE_TUNNEL=y
CONFIG_INET_XFRM_MODE_BEET=y
# CONFIG_INET_LRO is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IPV6=m
# CONFIG_IPV6_PRIVACY is not set
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_MIP6 is not set
# CONFIG_INET6_XFRM_TUNNEL is not set
# CONFIG_INET6_TUNNEL is not set
CONFIG_INET6_XFRM_MODE_TRANSPORT=m
CONFIG_INET6_XFRM_MODE_TUNNEL=m
CONFIG_INET6_XFRM_MODE_BEET=m
# CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
CONFIG_IPV6_SIT=m
CONFIG_IPV6_NDISC_NODETYPE=y
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_IPV6_MULTIPLE_TABLES is not set
# CONFIG_IPV6_MROUTE is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
CONFIG_NETFILTER_ADVANCED=y
# Core Netfilter Configuration
# CONFIG_NETFILTER_NETLINK_QUEUE is not set
# CONFIG_NETFILTER_NETLINK_LOG is not set
# CONFIG_NF_CONNTRACK is not set
# CONFIG_NETFILTER_TPROXY is not set
CONFIG_NETFILTER_XTABLES=m
# CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set
# CONFIG_NETFILTER_XT_TARGET_DSCP is not set
# CONFIG_NETFILTER_XT_TARGET_HL is not set
# CONFIG_NETFILTER_XT_TARGET_MARK is not set
# CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
# CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
# CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
# CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
# CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set
# CONFIG_NETFILTER_XT_MATCH_COMMENT is not set
# CONFIG_NETFILTER_XT_MATCH_DCCP is not set
# CONFIG_NETFILTER_XT_MATCH_DSCP is not set
# CONFIG_NETFILTER_XT_MATCH_ESP is not set
# CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_HL is not set
# CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set
# CONFIG_NETFILTER_XT_MATCH_LENGTH is not set
# CONFIG_NETFILTER_XT_MATCH_LIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_MAC is not set
# CONFIG_NETFILTER_XT_MATCH_MARK is not set
# CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set
# CONFIG_NETFILTER_XT_MATCH_OWNER is not set
# CONFIG_NETFILTER_XT_MATCH_POLICY is not set
# CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set
# CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
# CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
# CONFIG_NETFILTER_XT_MATCH_REALM is not set
# CONFIG_NETFILTER_XT_MATCH_RECENT is not set
# CONFIG_NETFILTER_XT_MATCH_SCTP is not set
# CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
# CONFIG_NETFILTER_XT_MATCH_STRING is not set
# CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
# CONFIG_NETFILTER_XT_MATCH_TIME is not set
# CONFIG_NETFILTER_XT_MATCH_U32 is not set
# CONFIG_IP_VS is not set
# IP: Netfilter Configuration
# CONFIG_NF_DEFRAG_IPV4 is not set
# CONFIG_IP_NF_QUEUE is not set
CONFIG_IP_NF_IPTABLES=m
# CONFIG_IP_NF_MATCH_ADDRTYPE is not set
# CONFIG_IP_NF_MATCH_AH is not set
# CONFIG_IP_NF_MATCH_ECN is not set
# CONFIG_IP_NF_MATCH_TTL is not set
CONFIG_IP_NF_FILTER=m
# CONFIG_IP_NF_TARGET_REJECT is not set
# CONFIG_IP_NF_TARGET_LOG is not set
# CONFIG_IP_NF_TARGET_ULOG is not set
CONFIG_IP_NF_MANGLE=m
# CONFIG_IP_NF_TARGET_ECN is not set
# CONFIG_IP_NF_TARGET_TTL is not set
# CONFIG_IP_NF_RAW is not set
# CONFIG_IP_NF_ARPTABLES is not set
# IPv6: Netfilter Configuration
# CONFIG_IP6_NF_QUEUE is not set
# CONFIG_IP6_NF_IPTABLES is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_PHONET is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
CONFIG_WIRELESS=y
# CONFIG_CFG80211 is not set
# CONFIG_WIRELESS_OLD_REGULATORY is not set
# CONFIG_WIRELESS_EXT is not set
# CONFIG_LIB80211 is not set
# CONFIG_MAC80211 is not set
# CONFIG_WIMAX is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
# CONFIG_MTD is not set
CONFIG_OF_DEVICE=y
CONFIG_OF_I2C=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_FD is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_UMEM is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_SX8 is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=8192
# CONFIG_BLK_DEV_XIP is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_XILINX_SYSACE is not set
# CONFIG_XILINX_SYSACE_OLD is not set
# CONFIG_BLK_DEV_HD is not set
CONFIG_MISC_DEVICES=y
# CONFIG_PHANTOM is not set
# CONFIG_SGI_IOC4 is not set
# CONFIG_TIFM_CORE is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_HP_ILO is not set
# CONFIG_ISL29003 is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_93CX6 is not set
CONFIG_XILINX_DRIVERS=y
CONFIG_NEED_XILINX_LLDMA=y
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
# CONFIG_SCSI is not set
# CONFIG_SCSI_DMA is not set
# CONFIG_SCSI_NETLINK is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# Enable only one of the two stacks, unless you know what you are doing
# CONFIG_FIREWIRE is not set
# CONFIG_IEEE1394 is not set
# CONFIG_I2O is not set
# CONFIG_MACINTOSH_DRIVERS is not set
CONFIG_NETDEVICES=y
CONFIG_COMPAT_NET_DEV_OPS=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_VETH is not set
# CONFIG_ARCNET is not set
# CONFIG_PHYLIB is not set
CONFIG_NET_ETHERNET=y
CONFIG_MII=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NET_VENDOR_3COM is not set
# CONFIG_ETHOC is not set
# CONFIG_DNET is not set
# CONFIG_NET_TULIP is not set
# CONFIG_HP100 is not set
# CONFIG_IBM_NEW_EMAC is not set
# CONFIG_IBM_NEW_EMAC_ZMII is not set
# CONFIG_IBM_NEW_EMAC_RGMII is not set
# CONFIG_IBM_NEW_EMAC_TAH is not set
# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
# CONFIG_NET_PCI is not set
# CONFIG_B44 is not set
# CONFIG_XILINX_EMAC is not set
# CONFIG_XILINX_EMACLITE is not set
# CONFIG_ATL2 is not set
CONFIG_NETDEV_1000=y
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
# CONFIG_E1000 is not set
# CONFIG_E1000E is not set
# CONFIG_IP1000 is not set
# CONFIG_IGB is not set
# CONFIG_IGBVF is not set
# CONFIG_NS83820 is not set
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
# CONFIG_R8169 is not set
# CONFIG_SIS190 is not set
# CONFIG_SKGE is not set
# CONFIG_SKY2 is not set
# CONFIG_VIA_VELOCITY is not set
# CONFIG_TIGON3 is not set
# CONFIG_BNX2 is not set
# CONFIG_QLA3XXX is not set
# CONFIG_ATL1 is not set
# CONFIG_XILINX_TEMAC is not set
# CONFIG_ATL1E is not set
CONFIG_XILINX_LLTEMAC=y
# CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_RGMII is not set
CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_GMII=y
# CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_MII is not set
# CONFIG_XILINX_LLTEMAC_NATIONAL_DP83865_GMII is not set
# CONFIG_ATL1C is not set
# CONFIG_JME is not set
# CONFIG_NETDEV_10000 is not set
# CONFIG_TR is not set
# Wireless LAN
# CONFIG_WLAN_PRE80211 is not set
# CONFIG_WLAN_80211 is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_ISDN is not set
# CONFIG_PHONE is not set
# Input device support
CONFIG_INPUT=y
# CONFIG_INPUT_FF_MEMLESS is not set
# CONFIG_INPUT_POLLDEV is not set
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
# CONFIG_INPUT_JOYDEV is not set
# CONFIG_INPUT_EVDEV is not set
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
CONFIG_MOUSE_PS2_ALPS=y
CONFIG_MOUSE_PS2_LOGIPS2PP=y
CONFIG_MOUSE_PS2_SYNAPTICS=y
CONFIG_MOUSE_PS2_TRACKPOINT=y
# CONFIG_MOUSE_PS2_ELANTECH is not set
# CONFIG_MOUSE_PS2_TOUCHKIT is not set
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
# CONFIG_INPUT_TOUCHSCREEN is not set
# CONFIG_INPUT_MISC is not set
# Hardware I/O ports
CONFIG_SERIO=y
# CONFIG_SERIO_I8042 is not set
CONFIG_SERIO_SERPORT=y
# CONFIG_SERIO_PCIPS2 is not set
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_XILINXPS2 is not set
# CONFIG_SERIO_XILINX_XPS_PS2 is not set
# CONFIG_SERIO_RAW is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_DEVKMEM=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_NOZOMI is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
CONFIG_SERIAL_UARTLITE=y
CONFIG_SERIAL_UARTLITE_CONSOLE=y
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_JSM is not set
# CONFIG_SERIAL_OF_PLATFORM_NWPSERIAL is not set
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_HVC_UDBG is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=m
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
# CONFIG_NVRAM is not set
# CONFIG_GEN_RTC is not set
CONFIG_XILINX_HWICAP=y
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
CONFIG_DEVPORT=y
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_HELPER_AUTO=y
# I2C Hardware Bus support
# PC SMBus host controller drivers
# CONFIG_I2C_ALI1535 is not set
# CONFIG_I2C_ALI1563 is not set
# CONFIG_I2C_ALI15X3 is not set
# CONFIG_I2C_AMD756 is not set
# CONFIG_I2C_AMD8111 is not set
# CONFIG_I2C_I801 is not set
# CONFIG_I2C_ISCH is not set
# CONFIG_I2C_PIIX4 is not set
# CONFIG_I2C_NFORCE2 is not set
# CONFIG_I2C_SIS5595 is not set
# CONFIG_I2C_SIS630 is not set
# CONFIG_I2C_SIS96X is not set
# CONFIG_I2C_VIA is not set
# CONFIG_I2C_VIAPRO is not set
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_IBM_IIC is not set
# CONFIG_I2C_MPC is not set
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_SIMTEC is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_TAOS_EVM is not set
# Graphics adapter I2C/DDC channel drivers
# CONFIG_I2C_VOODOO3 is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_STUB is not set
# Miscellaneous I2C Chip support
# CONFIG_DS1682 is not set
# CONFIG_SENSORS_PCF8574 is not set
# CONFIG_PCF8575 is not set
# CONFIG_SENSORS_PCA9539 is not set
# CONFIG_SENSORS_MAX6875 is not set
# CONFIG_SENSORS_TSL2550 is not set
CONFIG_I2C_DEBUG_CORE=y
CONFIG_I2C_DEBUG_ALGO=y
# CONFIG_I2C_DEBUG_BUS is not set
# CONFIG_I2C_DEBUG_CHIP is not set
# CONFIG_SPI is not set
CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
# CONFIG_GPIOLIB is not set
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
# CONFIG_HWMON is not set
# CONFIG_THERMAL is not set
# CONFIG_THERMAL_HWMON is not set
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
# Multifunction device drivers
# CONFIG_MFD_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_REGULATOR is not set
# Multimedia devices
# Multimedia core support
# CONFIG_VIDEO_DEV is not set
# CONFIG_DVB_CORE is not set
# CONFIG_VIDEO_MEDIA is not set
# Multimedia drivers
# CONFIG_DAB is not set
# Graphics support
# CONFIG_AGP is not set
# CONFIG_DRM is not set
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
# CONFIG_SOUND is not set
# CONFIG_HID_SUPPORT is not set
# CONFIG_USB_SUPPORT is not set
# CONFIG_UWB is not set
# CONFIG_MMC is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
# CONFIG_EDAC is not set
# CONFIG_RTC_CLASS is not set
# CONFIG_DMADEVICES is not set
# CONFIG_AUXDISPLAY is not set
CONFIG_XILINX_EDK=y
# CONFIG_XILINX_LLDMA_USE_DCR is not set
# CONFIG_UIO is not set
# CONFIG_STAGING is not set
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT2_FS_XIP is not set
# CONFIG_EXT3_FS is not set
# CONFIG_EXT4_FS is not set
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
CONFIG_FILE_LOCKING=y
# CONFIG_XFS_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
CONFIG_DNOTIFY=y
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_QUOTA is not set
CONFIG_AUTOFS_FS=y
CONFIG_AUTOFS4_FS=y
CONFIG_FUSE_FS=m
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
# CONFIG_PROC_KCORE is not set
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_HUGETLB_PAGE is not set
# CONFIG_CONFIGFS_FS is not set
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_CRAMFS=y
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
CONFIG_ROMFS_FS=y
CONFIG_ROMFS_BACKED_BY_BLOCK=y
# CONFIG_ROMFS_BACKED_BY_MTD is not set
# CONFIG_ROMFS_BACKED_BY_BOTH is not set
CONFIG_ROMFS_ON_BLOCK=y
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_NILFS2_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
# CONFIG_NFS_V4 is not set
CONFIG_ROOT_NFS=y
CONFIG_NFSD=y
CONFIG_NFSD_V3=y
# CONFIG_NFSD_V3_ACL is not set
# CONFIG_NFSD_V4 is not set
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
# CONFIG_RPCSEC_GSS_KRB5 is not set
# CONFIG_RPCSEC_GSS_SPKM3 is not set
CONFIG_SMB_FS=y
# CONFIG_SMB_NLS_DEFAULT is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
CONFIG_NLS_ASCII=m
CONFIG_NLS_ISO8859_1=m
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=m
# CONFIG_DLM is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_GENERIC_FIND_LAST_BIT=y
CONFIG_CRC_CCITT=y
# CONFIG_CRC16 is not set
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
CONFIG_HAVE_LMB=y
CONFIG_NLATTR=y
# Kernel hacking
# CONFIG_PRINTK_TIME is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_MAGIC_SYSRQ is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_DEBUG_FS is not set
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_KERNEL is not set
CONFIG_DEBUG_BUGVERBOSE=y
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_RCU_CPU_STALL_DETECTOR is not set
# CONFIG_LATENCYTOP is not set
CONFIG_SYSCTL_SYSCALL_CHECK=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_TRACING_SUPPORT=y
# Tracers
# CONFIG_FUNCTION_TRACER is not set
# CONFIG_PREEMPT_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_CONTEXT_SWITCH_TRACER is not set
# CONFIG_EVENT_TRACER is not set
# CONFIG_BOOT_TRACER is not set
# CONFIG_TRACE_BRANCH_PROFILING is not set
# CONFIG_STACK_TRACER is not set
# CONFIG_KMEMTRACE is not set
# CONFIG_WORKQUEUE_TRACER is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
CONFIG_PRINT_STACK_DEPTH=64
# CONFIG_IRQSTACKS is not set
# CONFIG_PPC_EARLY_DEBUG is not set
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
# CONFIG_SECURITY_FILE_CAPABILITIES is not set
CONFIG_CRYPTO=y
# Crypto core or helper
# CONFIG_CRYPTO_FIPS is not set
# CONFIG_CRYPTO_MANAGER is not set
# CONFIG_CRYPTO_MANAGER2 is not set
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
# CONFIG_CRYPTO_CBC is not set
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
# CONFIG_CRYPTO_HMAC is not set
# CONFIG_CRYPTO_XCBC is not set
# Digest
# CONFIG_CRYPTO_CRC32C is not set
# CONFIG_CRYPTO_MD4 is not set
# CONFIG_CRYPTO_MD5 is not set
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
# CONFIG_CRYPTO_SHA1 is not set
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
# CONFIG_CRYPTO_AES is not set
# CONFIG_CRYPTO_ANUBIS is not set
# CONFIG_CRYPTO_ARC4 is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
# CONFIG_CRYPTO_DES is not set
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_ZLIB is not set
# CONFIG_CRYPTO_LZO is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_HIFN_795X is not set
# CONFIG_CRYPTO_DEV_PPC4XX is not set
# CONFIG_PPC_CLOCK is not set
# CONFIG_VIRTUALIZATION is not set
MHS file:
# Created by Base System Builder Wizard for Xilinx EDK 10.1.02 Build EDK_K_SP2.5
# Wed Jul 02 14:49:19 2008
# Target Board:  Memec Virtex-4 FX12 MM Development Board Rev 1
# Family:    virtex4
# Device:    XC4VFX12
# Package:   SF363
# Speed Grade:  -10
# Processor: ppc405_0
# Processor clock frequency: 300.00 MHz
# Bus clock frequency: 100.00 MHz
# On Chip Memory :  16 KB
# Total Off Chip Memory :  64 MB
# - DDR_SDRAM_32Mx16 =  64 MB
 PARAMETER VERSION = 2.1.0
 PORT fpga_0_RS232_RX_pin = fpga_0_RS232_RX, DIR = I
 PORT fpga_0_RS232_TX_pin = fpga_0_RS232_TX, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_Clk_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_Clk, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_Clk_n_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_Clk_n, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_Addr_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_Addr, DIR = O, VEC = [12:0]
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_BankAddr_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_BankAddr, DIR = O, VEC = [1:0]
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_CAS_n_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_CAS_n, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_CE_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_CE, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_CS_n_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_CS_n, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_RAS_n_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_RAS_n, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_WE_n_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_WE_n, DIR = O
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_DM_pin = fpga_0_DDR_SDRAM_32Mx16_DDR_DM, DIR = O, VEC = [1:0]
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_DQS = fpga_0_DDR_SDRAM_32Mx16_DDR_DQS, DIR = IO, VEC = [1:0]
 PORT fpga_0_DDR_SDRAM_32Mx16_DDR_DQ = fpga_0_DDR_SDRAM_32Mx16_DDR_DQ, DIR = IO, VEC = [15:0]
 PORT fpga_0_TriMode_MAC_GMII_GMII_TXD_0_pin = fpga_0_TriMode_MAC_GMII_GMII_TXD_0, DIR = O, VEC = [7:0]
 PORT fpga_0_TriMode_MAC_GMII_GMII_TX_EN_0_pin = fpga_0_TriMode_MAC_GMII_GMII_TX_EN_0, DIR = O
 PORT fpga_0_TriMode_MAC_GMII_GMII_TX_ER_0_pin = fpga_0_TriMode_MAC_GMII_GMII_TX_ER_0, DIR = O
 PORT fpga_0_TriMode_MAC_GMII_GMII_TX_CLK_0_pin = fpga_0_TriMode_MAC_GMII_GMII_TX_CLK_0, DIR = O
 PORT fpga_0_TriMode_MAC_GMII_GMII_RXD_0_pin = fpga_0_TriMode_MAC_GMII_GMII_RXD_0, DIR = I, VEC = [7:0]
 PORT fpga_0_TriMode_MAC_GMII_GMII_RX_DV_0_pin = fpga_0_TriMode_MAC_GMII_GMII_RX_DV_0, DIR = I
 PORT fpga_0_TriMode_MAC_GMII_GMII_RX_ER_0_pin = fpga_0_TriMode_MAC_GMII_GMII_RX_ER_0, DIR = I
 PORT fpga_0_TriMode_MAC_GMII_GMII_RX_CLK_0_pin = fpga_0_TriMode_MAC_GMII_GMII_RX_CLK_0, DIR = I
 PORT fpga_0_TriMode_MAC_GMII_MII_TX_CLK_0_pin = fpga_0_TriMode_MAC_GMII_MII_TX_CLK_0, DIR = I
 PORT fpga_0_TriMode_MAC_GMII_MDIO_0_pin = fpga_0_TriMode_MAC_GMII_MDIO_0, DIR = IO
 PORT fpga_0_TriMode_MAC_GMII_MDC_0_pin = fpga_0_TriMode_MAC_GMII_MDC_0, DIR = O
 PORT fpga_0_TriMode_MAC_GMII_TemacPhy_RST_n_pin = fpga_0_TriMode_MAC_GMII_TemacPhy_RST_n, DIR = O
 PORT sys_clk_pin = dcm_clk_s, DIR = I, SIGIS = CLK, CLK_FREQ = 100000000
 PORT sys_rst_pin = sys_rst_s, DIR = I, RST_POLARITY = 0, SIGIS = RST
BEGIN ppc405_virtex4
 PARAMETER INSTANCE = ppc405_0
 PARAMETER HW_VER = 2.01.a
 PARAMETER C_FASTEST_PLB_CLOCK = DPLB1
 PARAMETER C_IDCR_BASEADDR = 0b0100000000
 PARAMETER C_IDCR_HIGHADDR = 0b0111111111
 BUS_INTERFACE JTAGPPC = jtagppc_0_0
 BUS_INTERFACE IPLB0 = plb
 BUS_INTERFACE DPLB0 = plb
 BUS_INTERFACE ISOCM = ppc405_0_iocm
 BUS_INTERFACE DSOCM = ppc405_0_docm
 BUS_INTERFACE IPLB1 = ppc405_0_iplb1
 BUS_INTERFACE DPLB1 = ppc405_0_dplb1
 BUS_INTERFACE RESETPPC = ppc_reset_bus
 PORT BRAMISOCMCLK = sys_clk_s
 PORT BRAMDSOCMCLK = sys_clk_s
 PORT CPMC405CLOCK = proc_clk_s
 PORT EICC405EXTINPUTIRQ = EICC405EXTINPUTIRQ
END
BEGIN jtagppc_cntlr
 PARAMETER INSTANCE = jtagppc_0
 PARAMETER HW_VER = 2.01.c
 BUS_INTERFACE JTAGPPC0 = jtagppc_0_0
END
BEGIN plb_v46
 PARAMETER INSTANCE = plb
 PARAMETER C_DCR_INTFCE = 0
 PARAMETER C_NUM_CLK_PLB2OPB_REARB = 100
 PARAMETER HW_VER = 1.03.a
 PORT PLB_Clk = sys_clk_s
 PORT SYS_Rst = sys_bus_reset
END
BEGIN xps_uartlite
 PARAMETER INSTANCE = RS232
 PARAMETER HW_VER = 1.00.a
 PARAMETER C_BAUDRATE = 115200
 PARAMETER C_DATA_BITS = 8
 PARAMETER C_ODD_PARITY = 0
 PARAMETER C_USE_PARITY = 0
 PARAMETER C_SPLB_CLK_FREQ_HZ = 100000000
 PARAMETER C_BASEADDR = 0x84000000
 PARAMETER C_HIGHADDR = 0x8400ffff
 BUS_INTERFACE SPLB = plb
 PORT RX = fpga_0_RS232_RX
 PORT TX = fpga_0_RS232_TX
END
BEGIN xps_ll_temac
 PARAMETER INSTANCE = TriMode_MAC_GMII
 PARAMETER HW_VER = 1.01.b
 PARAMETER C_NUM_IDELAYCTRL = 3
 PARAMETER C_IDELAYCTRL_LOC = IDELAYCTRL_X1Y0-IDELAYCTRL_X2Y2-IDELAYCTRL_X1Y1
 PARAMETER C_BUS2CORE_CLK_RATIO = 1
 PARAMETER C_BASEADDR = 0x81c00000
 PARAMETER C_HIGHADDR = 0x81c0ffff
 PARAMETER C_TEMAC0_TXFIFO = 8192
 PARAMETER C_TEMAC0_TXCSUM = 1
 PARAMETER C_TEMAC0_RXFIFO = 16384
 PARAMETER C_TEMAC0_RXCSUM = 1
 BUS_INTERFACE LLINK0 = TriMode_MAC_GMII_LLINK0
 PORT GMII_TXD_0 = fpga_0_TriMode_MAC_GMII_GMII_TXD_0
 PORT GMII_TX_EN_0 = fpga_0_TriMode_MAC_GMII_GMII_TX_EN_0
 PORT GMII_TX_ER_0 = fpga_0_TriMode_MAC_GMII_GMII_TX_ER_0
 PORT GMII_TX_CLK_0 = fpga_0_TriMode_MAC_GMII_GMII_TX_CLK_0
 PORT GMII_RXD_0 = fpga_0_TriMode_MAC_GMII_GMII_RXD_0
 PORT GMII_RX_DV_0 = fpga_0_TriMode_MAC_GMII_GMII_RX_DV_0
 PORT GMII_RX_ER_0 = fpga_0_TriMode_MAC_GMII_GMII_RX_ER_0
 PORT GMII_RX_CLK_0 = fpga_0_TriMode_MAC_GMII_GMII_RX_CLK_0
 PORT MII_TX_CLK_0 = fpga_0_TriMode_MAC_GMII_MII_TX_CLK_0
 PORT MDIO_0 = fpga_0_TriMode_MAC_GMII_MDIO_0
 PORT MDC_0 = fpga_0_TriMode_MAC_GMII_MDC_0
 PORT TemacPhy_RST_n = fpga_0_TriMode_MAC_GMII_TemacPhy_RST_n
 PORT GTX_CLK_0 = temac_clk_s
 PORT REFCLK = clk_200mhz_s
 PORT LlinkTemac0_CLK = sys_clk_s
 PORT TemacIntc0_Irpt = TriMode_MAC_GMII_TemacIntc0_Irpt
END
BEGIN mpmc
 PARAMETER INSTANCE = DDR_SDRAM_32Mx16
 PARAMETER HW_VER = 4.03.a
 PARAMETER C_NUM_PORTS = 3
 PARAMETER C_MEM_PARTNO = HYB25D512160BC-6
 PARAMETER C_NUM_IDELAYCTRL = 2
 PARAMETER C_IDELAYCTRL_LOC = IDELAYCTRL_X0Y3-IDELAYCTRL_X0Y2
 PARAMETER C_MEM_DATA_WIDTH = 16
 PARAMETER C_MEM_DQS_WIDTH = 2
 PARAMETER C_MEM_DM_WIDTH = 2
 PARAMETER C_MEM_TYPE = DDR
 PARAMETER C_PIM0_BASETYPE = 2
 PARAMETER C_PIM1_BASETYPE = 2
 PARAMETER C_PIM2_BASETYPE = 3
 PARAMETER C_MPMC_CLK0_PERIOD_PS = 10000
 PARAMETER C_SDMA2_PI2LL_CLK_RATIO = 1
 PARAMETER C_MPMC_BASEADDR = 0x00000000
 PARAMETER C_MPMC_HIGHADDR = 0x03ffffff
 PARAMETER C_SDMA_CTRL_BASEADDR = 0x84600000
 PARAMETER C_SDMA_CTRL_HIGHADDR = 0x8460ffff
 BUS_INTERFACE SPLB0 = ppc405_0_iplb1
 BUS_INTERFACE SPLB1 = ppc405_0_dplb1
 BUS_INTERFACE SDMA_LL2 = TriMode_MAC_GMII_LLINK0
 BUS_INTERFACE SDMA_CTRL2 = plb
 PORT DDR_Clk = fpga_0_DDR_SDRAM_32Mx16_DDR_Clk
 PORT DDR_Clk_n = fpga_0_DDR_SDRAM_32Mx16_DDR_Clk_n
 PORT DDR_Addr = fpga_0_DDR_SDRAM_32Mx16_DDR_Addr
 PORT DDR_BankAddr = fpga_0_DDR_SDRAM_32Mx16_DDR_BankAddr
 PORT DDR_CAS_n = fpga_0_DDR_SDRAM_32Mx16_DDR_CAS_n
 PORT DDR_CE = fpga_0_DDR_SDRAM_32Mx16_DDR_CE
 PORT DDR_CS_n = fpga_0_DDR_SDRAM_32Mx16_DDR_CS_n
 PORT DDR_RAS_n = fpga_0_DDR_SDRAM_32Mx16_DDR_RAS_n
 PORT DDR_WE_n = fpga_0_DDR_SDRAM_32Mx16_DDR_WE_n
 PORT DDR_DM = fpga_0_DDR_SDRAM_32Mx16_DDR_DM
 PORT DDR_DQS = fpga_0_DDR_SDRAM_32Mx16_DDR_DQS
 PORT DDR_DQ = fpga_0_DDR_SDRAM_32Mx16_DDR_DQ
 PORT MPMC_Clk0 = sys_clk_s
 PORT MPMC_Clk90 = DDR_SDRAM_32Mx16_mpmc_clk_90_s
 PORT SDMA2_Clk = sys_clk_s
 PORT MPMC_Clk_200MHz = clk_200mhz_s
 PORT MPMC_Rst = sys_periph_reset
 PORT SDMA2_Rx_IntOut = DDR_SDRAM_32Mx16_SDMA2_Rx_IntOut
 PORT SDMA2_Tx_IntOut = DDR_SDRAM_32Mx16_SDMA2_Tx_IntOut
END
BEGIN xps_timer
 PARAMETER INSTANCE = xps_timer_1
 PARAMETER C_COUNT_WIDTH = 32
 PARAMETER C_ONE_TIMER_ONLY = 1
 PARAMETER C_BASEADDR = 0x83c00000
 PARAMETER C_HIGHADDR = 0x83c0ffff
 PORT Interrupt = xps_timer_1_Interrupt
END
BEGIN isocm_v10
 PARAMETER INSTANCE = ppc405_0_iocm
 PARAMETER HW_VER = 2.00.b
 PARAMETER C_ISCNTLVALUE = 0xa5
 PORT ISOCM_Clk = sys_clk_s
 PORT sys_rst = sys_bus_reset
END
BEGIN isbram_if_cntlr
 PARAMETER INSTANCE = ppc405_0_iocm_cntlr
 PARAMETER HW_VER = 3.00.b
 PARAMETER C_BASEADDR = 0xffffe000
 PARAMETER C_HIGHADDR = 0xffffffff
 BUS_INTERFACE DCR_WRITE_PORT = isocm_porta
 BUS_INTERFACE INSTRN_READ_PORT = isocm_portb
END
BEGIN bram_block
 PARAMETER INSTANCE = isocm_bram
 BUS_INTERFACE PORTA = isocm_porta
 BUS_INTERFACE PORTB = isocm_portb
END
BEGIN dsocm_v10
 PARAMETER INSTANCE = ppc405_0_docm
 PARAMETER C_DSCNTLVALUE = 0xa5
 PORT DSOCM_Clk = sys_clk_s
END
BEGIN dsbram_if_cntlr
 PARAMETER INSTANCE = ppc405_0_docm_cntlr
 PARAMETER C_BASEADDR = 0xc2308000
 PARAMETER C_HIGHADDR = 0xc2309fff
 BUS_INTERFACE PORTA = dsocm_porta
END
BEGIN bram_block
 PARAMETER INSTANCE = dsocm_bram
END
BEGIN plb_v46
 PARAMETER INSTANCE = ppc405_0_iplb1
END
BEGIN plb_v46
 PARAMETER INSTANCE = ppc405_0_dplb1
END
BEGIN clock_generator
 PARAMETER INSTANCE = clock_generator_0
 PARAMETER C_EXT_RESET_HIGH = 1
 PARAMETER C_CLKIN_FREQ = 100000000
 PARAMETER C_CLKOUT0_FREQ = 100000000
 PARAMETER C_CLKOUT0_BUF = TRUE
 PARAMETER C_CLKOUT0_PHASE = 0
 PARAMETER C_CLKOUT0_GROUP = DCM0
 PARAMETER C_CLKOUT1_FREQ = 300000000
 PARAMETER C_CLKOUT1_BUF = TRUE
 PARAMETER C_CLKOUT1_PHASE = 0
 PARAMETER C_CLKOUT1_GROUP = DCM0
 PARAMETER C_CLKOUT2_FREQ = 100000000
 PARAMETER C_CLKOUT2_BUF = TRUE
 PARAMETER C_CLKOUT2_PHASE = 90
 PARAMETER C_CLKOUT2_GROUP = DCM0
 PARAMETER C_CLKOUT3_FREQ = 200000000
 PARAMETER C_CLKOUT3_BUF = TRUE
 PARAMETER C_CLKOUT3_PHASE = 0
 PARAMETER C_CLKOUT3_GROUP = NONE
 PARAMETER C_CLKOUT4_FREQ = 125000000
 PARAMETER C_CLKOUT4_BUF = TRUE
 PARAMETER C_CLKOUT4_PHASE = 0
 PARAMETER C_CLKOUT4_GROUP = NONE
 PORT CLKOUT0 = sys_clk_s
 PORT CLKOUT1 = proc_clk_s
 PORT CLKOUT2 = DDR_SDRAM_32Mx16_mpmc_clk_90_s
 PORT CLKOUT3 = clk_200mhz_s
 PORT CLKOUT4 = temac_clk_s
 PORT CLKIN = dcm_clk_s
 PORT LOCKED = Dcm_all_locked
 PORT RST = net_gnd
END
BEGIN proc_sys_reset
 PARAMETER INSTANCE = proc_sys_reset_0
 PARAMETER HW_VER = 2.00.a
 PARAMETER C_EXT_RESET_HIGH = 0
 BUS_INTERFACE RESETPPC0 = ppc_reset_bus
 PORT Slowest_sync_clk = sys_clk_s
 PORT Dcm_locked = Dcm_all_locked
 PORT Ext_Reset_In = sys_rst_s
 PORT Bus_Struct_Reset = sys_bus_reset
 PORT Peripheral_Reset = sys_periph_reset
END
BEGIN xps_intc
 PARAMETER INSTANCE = xps_intc_0
 PARAMETER C_BASEADDR = 0x81800000
 PARAMETER C_HIGHADDR = 0x8180ffff
 PORT Irq = EICC405EXTINPUTIRQ
 PORT Intr = TriMode_MAC_GMII_TemacIntc0_Irpt & xps_timer_1_Interrupt & DDR_SDRAM_32Mx16_SDMA2_Rx_IntOut & DDR_SDRAM_32Mx16_SDMA2_Tx_IntOut
END
Expert Contributor
0
Have you done any testing on the hardware system before running Linux on it?
The EDK lets you run a test application to verify memory.  I'm just wandering if this is a h/w or s/w problem as you've done the right things in general.
I can't see the problem.  It's easier for you to do a diff on the kernel config against the one we provide, and the device tree also.  I can't see a problem, but a diff is much more effective than a visual inspection in my experience.
Have you gone in a dumped the __log_buf in XMD as recommended on the kernel debug page of the wiki as it doesn't sound like it crashed to me since you don't see a crash on the console?  That may yield nothing new and is a pain, but when you don't have success you have to start digging deeper.
I have hacked in the my own function to run before instead of the standard init that gets called on the ramdisk just as a test.
When you stop the processor in XMD, the MMU is still on and you can get the address of the function it's executing from the vmlinux image using objdump also.  That might be informative.
Hope those clues help. Hang in there, learning can be challenging.
Regular Contributor
0
Hello John,
thanks for reply and hints.
I did a memory test as well as the Avnet examples. All seems working fine and it does not crash randomly.
Another test:
I'm not sure it made sense or not, I used the prebuilt ramdisk image which is provided in the ELDK4.2 distribution.
The kernel stops after  "RAMDISK: gzip image found at block 0" but with a crash and console output. Would you have a look at?
Thanks for encouragement - sure I will dig into the sources  - for me it is a pain - I'm a hardware dude - my work stops a the device driver side normally.
But before I will try to verify my results on a ML403 or on my custom target with FX60.
Could you provide please a precompiled ML403 bitstream + simpleImage.initrd.virtex4-ML403.elf?
Do you test  "linux" against the MPMC or another memory ip core?
Best regards from Germany, Thomas
Expert Contributor
0
Hi Thomas,
Sounds like the memory is probably ok assuming the you made sure the memory test was really testing all of the memory.
Sorry I don't have a prebuilt bitstream for the 403 as I don't use that board.  BSB in the EDK does support that board so that it should be easy to build a system.
It sounds like you have taken our ramdisk from the wiki and tried it without success if I understand right, true?
If I get a chance, I'll try the ramdisk from the ELDK in one of my systems.
My testing is against systems built with BSB in the EDK and yes they do use MPMC and standard IP cores from the EDK.
Did you do those diffs on the device tree and .config files to understand the deltas?
Regular Contributor
0
Hi John,
I compared  the dts my and  the virtex405-ml405.dts.
I saw in virtex405-ml405.dts the memory is defined as:
    DDR_SDRAM: memory@0 {
        reg = < 0 0x8000000 >;
Surpricingly only the half memory size available on this board is in use.
I changed my dts file also to the half size and my board gets runing in some way, the console stops again as shown below.
However I debugged for a while and I found the kernel is up and running. Happily the telnetd is running and I could connect. :-)
Does documentation exist about the system memory layout?
Memory: 27700k/32768k available (3020k kernel code, 5068k reserved, 124k data, 1
21k bss, 136k init)
VFS: Mounted root (ext2 filesystem) readonly on device 1:0.
Freeing unused kernel memory: 136k init "console stops here"
Best regards,
Thomas
Regular Contributor
0
physcial memory layout
Hello John,
so this is a fix only to use the half memory. But howto use the entire memory?
It seems to be a common problem, like here:
http://forums.xilinx.com/xlnx/board/message?board.id=ELINUX&thread.id=1408&view=by_date_ascending&page=4
So there is a need of explicit control the physcial memory layout.
Do you know howto start?
Regards, Thomas
