Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
vjose
0
Document on Fixed Point arithmetic
Hi ,
I have to do a DSP algorithm with two 16 2's compliment bit numbers A (Q1.15 format ) and B(12.4 format) . I need to have the result in Q1.15 format . Can anyone suggest me a good concrete document on this topic.
With regards
Vintu
Expert Contributor
eilert
0
Re: Document on Fixed Point arithmetic
Hi Vintu,
very basic and formally you can do it like this:
Expand both numbers to 12.15 fixed format with respect ot the signedness.
Forget about the decimal point and do integer math. (there is no difference)
Snip out the 1.15 Result , which will be the 16 LSBs of the 12.15 number.
Done.
There may be potential to optimize the wordwidth, but you can also leave this to the logic optimization tools.
You have to be carefull if you are using  algorithms like CORDIC which might change the decimal point position in the result.
Also in multiplications you have to care about taking the right bits from the result which will have 24.30 format.
Have a nice synthesis
  Eilert
Expert Contributor
muzaffer
0
Consider the two types of operators you can use on Q numbers: addition/subtraction and multiplication (division is more complicated):
If you add two aligned Q numbers (ie the binary point is at the same location) you just add the regular bit patterns and adjust for growth like you would regular integers ie every N element addition gives you log2(N) extra bits. If numbers are not aligned (ala your example) you need to align them ie 1.15 + 12.4,11'b0 if that makes sense to you (or you need to add 11 zeros to the right of the number in 12.4 number to add it to 1.15 number).
Multiplication is somewhat easier. There is no need to align but the result grows by the sum of the inputs sizes ie:
1.15 x 12.4 = 13.19 ie you add whole sizes and fractional sizes separately. Of course then you have to round it back to your desired output or say you want the result in 1.15. You need to divide the result by 16 (to get rid of the 4 bits at the bottom) and truncate the number to 16 bits. Of course there is no guarantee that the result will fit into 16 bits.
This looks like a nice document: http://courses.cs.washington.edu/courses/cse467/08au/pdfs/lectures/11-FixedPointArithmetic.pdf
Expert Contributor
markcurry
0
Thanks for the reference muzaffer.
I've recommended the below reference multiple times.  It's written by a DSP guy more angled towards software, but I find the representation he uses is very useful for HW.  His paper lists some fundamental rules of fixed-point arithmetic - showing bit growth under common operations, and signedness concerns.
http://www.digitalsignallabs.com/fp.pdf
Mark
Expert Contributor
muzaffer
0
I like Randy's work a lot. He is active comp.dsp too.
