Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Regular Visitor
0
PlanAhead 12.1 Internal Exception- Partial Reconfiguration
  I get the following error in PlanAhead 12.1. I am designing an example PR Project with an Evaluation Licence.
# PlanAhead v12.1
# Build 61553 by hdbuild on Fri Apr 23 10:13:54 PDT 2010
# Current time: 5/31/10 11:02:21 AM
# Process ID: 976
# Platform: Windows
# This report is an indication that an internal PlanAhead error occurred.
# This information is useful for debugging. Please open a case with Xilinx
# Technical Support with this file and a testcase attached.
java.lang.NullPointerException
    at ui.views.p.v(SourceFile:611)
    at ui.views.p.a(SourceFile:1492)
    at ui.frmwork.Q.f(SourceFile:56)
    at ui.frmwork.Q.d(SourceFile:34)
    at ui.data.I.d(SourceFile:786)
    at ui.dlg.constr.Q.gw(SourceFile:263)
    at ui.dlg.common.h.actionPerformed(SourceFile:210)
    at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
    at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
    at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
    at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
    at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
    at java.awt.Component.processMouseEvent(Component.java:6263)
    at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
    at java.awt.Component.processEvent(Component.java:6028)
    at java.awt.Container.processEvent(Container.java:2041)
    at java.awt.Component.dispatchEventImpl(Component.java:4630)
    at java.awt.Container.dispatchEventImpl(Container.java:2099)
    at java.awt.Component.dispatchEvent(Component.java:4460)
    at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
    at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
    at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
    at java.awt.Container.dispatchEventImpl(Container.java:2085)
    at java.awt.Window.dispatchEventImpl(Window.java:2475)
    at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
    at ui.frmwork.aa.dispatchEvent(SourceFile:73)
    at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
    at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:178)
    at java.awt.Dialog$1.run(Dialog.java:1045)
    at java.awt.Dialog$3.run(Dialog.java:1097)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.awt.Dialog.show(Dialog.java:1095)
    at java.awt.Component.show(Component.java:1563)
    at java.awt.Component.setVisible(Component.java:1515)
    at java.awt.Window.setVisible(Window.java:841)
    at java.awt.Dialog.setVisible(Dialog.java:985)
    at ui.dlg.common.h.w(SourceFile:107)
    at ui.dlg.common.h.gY(SourceFile:116)
    at ui.dlg.constr.Q.gY(SourceFile:283)
    at ui.views.cmdhandler.o.run(SourceFile:35)
    at ui.frmwork.U.atB(SourceFile:51)
    at ui.views.constr.e.actionPerformed(SourceFile:187)
    at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(SourceFile:83)
    at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:272)
    at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
    at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
    at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Please give me a solution. Thank you.
Swami
0
Re: PlanAhead 12.1 Internal Exception- Partial Reconfiguration
What did you do  when  this happened?
It seems like you were creating a constraint.
This will help us reproduce the problem.
Krishnan
Regular Visitor
0
 yes. I was trying to create timing constraints...
Swami.
0
Which timing constraint?
Krishnan
Regular Visitor
0
 Timing constraints for partition pins..
Swami.
0
If you are able to reproduce, could you give the steps ?
If it is not possible to reproduce it, Could you describe the type of timing constraint that you were trying to create?
Krishnan
0
I am able to reproduce thsi problem creating TNM constraint on a pin.
Krishnan
0
This will be fixed in 12.2.
Unfortunately the only workaround is to manually enter PIN constraint to the UCF file directly.
You can open the ucf file from Source view and add the constraint there.
Krishnan
