Create Account
Username
Password
Forgot your password?
XClose Panel
Xilinx Home
Super Contributor
0
Spartan-3A DCM frequency align mode
is it supported? and pointers or info?
the only reference for this mode is for Spartan-3E,
Antti Lukats
0
Re: Spartan-3A DCM frequency align mode
5.5 years later....
i try to run the frequency generator from http://www.xilinx.com/products/boards/s3estarter/files/s3esk_frequency_generator.pdf on the Sparten3A development board.
I change the DCM_x1y1 to DCM_x1y3 in the ucf file and also  in the bitget command:
-g cfg_dfs_s_x1y3:1111000011111111xxx111xxxxx1xxxxxxxxxx1xxxxxxxxxxxxxxxxxxxxxxxxxxxxx01000000.
But it seems i missing something because i get lot of jitter on the output pin.
In the code, i also change from
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
to the
use IEEE.numeric_std.all;
with some change from std_logic_vector to unsinged. ( but the frequency is as expected, so i think i make there no mistakes)
Have anyone a idea what is wrong?
greetings
alex
Expert Contributor
0
alexhd wrote:
5.5 years later....
to the
greetings
alex
DCMs don't attenuate jitter like a PLL.
Changing to numeric_std from std_logic_arith is of course the right thing to do, but it has nothing to do with jitter.
Are you trying to monitor the output clock? Are you using the usual ODDR2 clock-forwarding trick? What does the input clock look like?
Yes, I do this for a living.
0
As in the linked pdf on page 11 described the dcm should only use the frequency information and produce a jitter "free" signal in the frequency aligned mode or not?
Is this mode not available on the Spartan3A? I did not found further information about this.
I put the signal on the sma output pin of the development board (as was done in the example code) . Without the ODDR2 clock-forwarding trick. i connected the sma output pin to an oscilloscope.
I dont monitor the input clk. I use the onboard 50 MHz.
Expert Contributor
0
Again, DCMs don't attenuate jitter like a PLL.
Well, using the ODDR2 for clock forwarding is vital because who knows how the signal is routed in the FPGA.
