- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Keeping Hierarchy causes packing error with PicoBlaze 6
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-26-2011 04:05 PM
I'm currently working on a system that incorporates a number of kcpsm6 units, which I want to be able to partially reconfigure. Each PicoBlaze is housed inside a wrapper component that holds both it and its program ROM. Before synthesizing my system, I placed a "keep hierarchy" constraint in this wrapper component so that it would remain distinct, and I could designate it as a reconfigurable partition. When I try to build my system in PlanAhead, I get a Pack:2811 error for each PicoBlaze tile. If I build a non-reconfigurable version of the system without applying the "keep hierarchy" constraints, everything works just fine. I've used "keep hierarchy" in this fashion on self-written components before, but never on a picoblaze. How could I solve this? The complete error message is below, and I've attached the code for my wrapper component.
ERROR:Pack:2811 - Directed packing was unable to obey the user design
constraints
(BLKNM=pico_tile_tmr_unit_0/pico_tile_tmr_unit_0/U
_proc/KCPSM6_SANDR) which requires the combination of the symbols listed
below to be packed into a single SLICE component.
The directed pack was not possible because: The top reasons for failure were:
-> A legal placement was never found for register symbol
"pico_tile_tmr_unit_0/pico_tile_tmr_unit_0/USER_LO
data_path_loop[0].low_hwbuild.shift_rotate_flop".
data_path_loop[1].low_hwbuild.shift_rotate_flop".
-> Function generator
pico_tile_tmr_unit_0/pico_tile_tmr_unit_0/USER_LOG
ata_path_loop[4].mid_shift_rotate.shift_rotate_lut
of the LUT6_2 and can only go into a LUT6 site.
ata_path_loop[6].msb_shift_rotate.shift_rotate_lut
data_path_loop[2].low_hwbuild.shift_rotate_flop".
data_path_loop[3].low_hwbuild.shift_rotate_flop".
ata_path_loop[2].mid_shift_rotate.shift_rotate_lut
data_path_loop[4].low_hwbuild.shift_rotate_flop".
data_path_loop[5].low_hwbuild.shift_rotate_flop".
data_path_loop[6].low_hwbuild.shift_rotate_flop".
The symbols involved are:
FLOP symbol
data_path_loop[0].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[0])
FLOP symbol
data_path_loop[2].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[2])
FLOP symbol
data_path_loop[4].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[4])
FLOP symbol
data_path_loop[6].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[6])
LUT symbol
data_path_loop[6].msb_shift_rotate.shift_rotate_lu
hift_rotate_value[6])
LUT symbol
data_path_loop[4].mid_shift_rotate.shift_rotate_lu
hift_rotate_value[4])
LUT symbol
data_path_loop[2].mid_shift_rotate.shift_rotate_lu
hift_rotate_value[2])
LUT symbol
data_path_loop[0].lsb_shift_rotate.shift_rotate_lu
hift_rotate_value[0])
LUT symbol
hift_rotate_value[7])
LUT symbol
hift_rotate_value[5])
LUT symbol
hift_rotate_value[3])
LUT symbol
hift_rotate_value[1])
FLOP symbol
data_path_loop[1].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[1])
FLOP symbol
data_path_loop[3].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[3])
FLOP symbol
data_path_loop[5].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[5])
FLOP symbol
data_path_loop[7].low_hwbuild.shift_rotate_flop" (Output Signal =
hift_rotate_result[7
Solved! Go to Solution.
Re: Keeping Hierarchy causes packing error with PicoBlaze 6
[ Edited ]- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-26-2011 04:09 PM - edited 01-26-2011 04:10 PM
Note: this error is not limited to PlanAhead, and it occurs whether I floorplan the design or not. If I try to synthesize my project in EDK with the keep hierarchy constraint active, I get the same error.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-27-2011 04:36 PM
Update: I can get my design to build in XPS if I set "keep hierarchy" to "soft" instead of "true." However, this does not help once I export the netlists to PlanAhead. I have discovered that all is well as long as only one of my reconfigurable partitions contains a PicoBlaze; however, if I attempt to create multiple PicoBlaze components in separate partitions, I get the same Pack error. I even tried synthesizing my system netlists with all of the PicoBlaze tiles as black boxes, synthesizing the PicoBlaze tile netlist in a separate project (with the "keep hierarchy" constraint removed), and using that to create the reconfigurable modules in PlanAhead; same problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-31-2011 12:59 PM
I found the problem (after much struggling)! It is probably analogous to this issue:
http://www.xilinx.com/support/answers/30705.htm
In my case, though, the offending constraint appears to be "hblknm" instead of "hlutnm." To solve the problem, I had to modify the "generate data_path_loop" section of kcpsm6.vhd. For each PicoBlaze partition in my design, I had to generate a new netlist from a version of kcpsm6.vhd which used a unique name for this code block, instead of "data_path_loop." So the netlists are generated from files that contain data_path_loop00, data_path_loop01, etc.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-15-2011 01:25 AM
Facing same issue, today, 3rd day of investigation, I finally found this thread which solved it.
But I'm wondering, is this really THE solution, editing something that rather is a black box to us?
Any information from the Xilinx/Picoblaze experts?
Best regards,
Mark Radisson
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-15-2011 02:19 AM
Probably not in this forum, maybe in:
http://forums.xilinx.com/t5/PicoBlaze/bd-p/PicoBla
"If it don't work in simulation, it won't work on the board."
